- To:
- Subject: Res: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt
- Date: Tue, 18 May 2010 07:01:12 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=rg9qPrmPmzIjX+Wa9X8ijLq8UKqmXLSvdBT2MFA8JzS32NOFzhxT3yd3vZw0/XqV1AtdjOBVx7c4cDYT00a41kfcm3pWnz+lV8AJDRVIb/MNe6t2oSsT/kxYUcIj8DtWADs74Nxk4BxTmadNWZqaHh/wlScPoSi7payjVyRo9rI=;
Because I want to do a program that use graphics interface and the command 'cgal_create_cmake_script' only work with text interface.
So, I'd to know how to create it.
De: Laurent Rineau (GeometryFactory) <>
Para:
Enviadas: Terça-feira, 18 de Maio de 2010 9:22:39
Assunto: Re: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt
On Tuesday 18 May 2010 14:06:37 Rogério Pozza wrote:
> I used the command 'cgal_create_cmake_script demo' with the example
> 'Convex_hull_2' and the CMakeLists.txt was generated right.
> But when I try with the example 'GraphicsView' (min.cpp) the
> CMakeLists.txt was generated wrong. I try with the command cmake-gui too.
There are already CMakeLists.txt files in those directories of the CGAL
installation. Why do you want to re-create them?
Laurent Rineau, PhD
- [cgal-discuss] Create CMakeListis.txt, rspozza, 05/16/2010
- Re: [cgal-discuss] Create CMakeListis.txt, Eric Berberich, 05/16/2010
- Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/16/2010
- Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/16/2010
- Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/18/2010
- Re: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Laurent Rineau (GeometryFactory), 05/18/2010
- Res: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/18/2010
- Re: Res: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Andreas Fabri, 05/18/2010
- Re: Res: Res: [cgal-discuss] Create CMakeListis.txt, Fernando Cacciola, 05/18/2010
