- To:
- Subject: Re: Res: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt
- Date: Tue, 18 May 2010 16:15:18 +0200
Hi Rogerio,
It is hard to automatize if you have several compilation units,
header files on which you have to run moc,....
It is out of the scope of the CGL project to offer
a cmake tutorial.
Try to get inspired by reading CMakeList.txt files.
andreas
On 18/05/2010 16:01, Rogério Pozza wrote:
Because I want to do a program that use graphics interface and the
command 'cgal_create_cmake_script' only work with text interface.
So, I'd to know how to create it.
*De:* Laurent Rineau (GeometryFactory)
*Para:*
*Enviadas:* Terça-feira, 18 de Maio de 2010 9:22:39
*Assunto:* Re: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt
On Tuesday 18 May 2010 14:06:37 Rogério Pozza wrote:
> I used the command 'cgal_create_cmake_script demo' with the example
> 'Convex_hull_2' and the CMakeLists.txt was generated right.
> But when I try with the example 'GraphicsView' (min.cpp) the
> CMakeLists.txt was generated wrong. I try with the command cmake-gui too.
There are already CMakeLists.txt files in those directories of the CGAL
installation. Why do you want to re-create them?
Laurent Rineau, PhD
- [cgal-discuss] Create CMakeListis.txt, rspozza, 05/16/2010
- Re: [cgal-discuss] Create CMakeListis.txt, Eric Berberich, 05/16/2010
- Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/16/2010
- Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/16/2010
- Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/18/2010
- Re: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Laurent Rineau (GeometryFactory), 05/18/2010
- Res: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/18/2010
- Re: Res: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Andreas Fabri, 05/18/2010
- Re: Res: Res: [cgal-discuss] Create CMakeListis.txt, Fernando Cacciola, 05/18/2010
