- To:
- Subject: Re: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt
- Date: Tue, 18 May 2010 14:22:39 +0200
On Tuesday 18 May 2010 14:06:37 Rogério Pozza wrote:
> I used the command 'cgal_create_cmake_script demo' with the example
> 'Convex_hull_2' and the CMakeLists.txt was generated right.
> But when I try with the example 'GraphicsView' (min.cpp) the
> CMakeLists.txt was generated wrong. I try with the command cmake-gui too.
There are already CMakeLists.txt files in those directories of the CGAL
installation. Why do you want to re-create them?
Laurent Rineau, PhD
- [cgal-discuss] Create CMakeListis.txt, rspozza, 05/16/2010
- Re: [cgal-discuss] Create CMakeListis.txt, Eric Berberich, 05/16/2010
- Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/16/2010
- Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/16/2010
- Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/18/2010
- Re: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Laurent Rineau (GeometryFactory), 05/18/2010
- Res: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Rogério Pozza, 05/18/2010
- Re: Res: Res: Res: Res: [cgal-discuss] Create CMakeListis.txt, Andreas Fabri, 05/18/2010
- Re: Res: Res: [cgal-discuss] Create CMakeListis.txt, Fernando Cacciola, 05/18/2010
