Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator
- To:
- Subject: Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator
- Date: Wed, 26 May 2010 17:48:52 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=KiNO5k7VwYIeSLiHrVvCNs+/4ItsWbfewKyAe3Oi32/aDvWLYXAwZSQZolX3Mt70es Rlviv820fH8OvrKHIwW3/FnwPQnAVRjIrjrq5FjMQ8ZTFHHY2xELK9VLAURsEtiwJiNj 3Hq+1Di33mXIWsMl34YbLngU+Wi6cNi8VyCIM=
Just one more question on the third template parameter 'Dummy_kernel'. I cannot see it is really used anywhere in the code. So why would changing it from Simple_cartesian_kernel to IGT solve the first issue when remeshing the cube?
template <class Polyhedron, class Kernel, class Dummy_kernel>
class AABB_polyhedral_oracle : public Polyhedron
Joe
please correct me if there is anything I missed:
On Tue, May 25, 2010 at 2:48 AM, Laurent Rineau (GeometryFactory) <> wrote:
On Friday 21 May 2010 09:27:10 fp2008 wrote:There are several issues.
> Hi Andreas,
> I attached three OFF files. The remeshing tool crashes quickly when
> processing box.off and glass-mug.off, though it gets stuck instead with
> flash.off.
** First, there is a non-exact use of the AABB_tree class, in the Polyhedron demo. Please apply the following patch:
--- demo/Polyhedron/Polyhedron_demo_remeshing_plugin_cgal_code.cpp.~BASE~ 2010-05-25 11:24:12.000000000 +0200
+++ demo/Polyhedron/Polyhedron_demo_remeshing_plugin_cgal_code.cpp 2010-05-21 15:12:43.000000000 +0200
@@ -110,10 +110,10 @@
// Types for meshing
-typedef CGAL::Simple_cartesian<double> Simple_cartesian_kernel;
+// typedef CGAL::Simple_cartesian<double> Simple_cartesian_kernel;
// input surface
-// typedef CGAL::Mesh_3::Robust_intersection_traits_3<Kernel> IGT;
-typedef CGAL::AABB_polyhedral_oracle<Polyhedron,Kernel,Simple_cartesian_kernel> Input_surface;
+typedef CGAL::Mesh_3::Robust_intersection_traits_3<Kernel> IGT;
+typedef CGAL::AABB_polyhedral_oracle<Polyhedron,Kernel,IGT> Input_surface;
// A base non-templated class, to allow
That will prevent the Surface_mesher from crashing on a simple cube surface. Actually, a cube a something particularly difficult to mesh:
- there are a lot of coplanar points,
- there are sharp edges (that the Surface_mesher package cannot mesh properly).
** Second, your file glass-mug.off is not a triangulated surface. Please use the menu entry Operations->Triangulate facets before launching the remeshing function.
** Third, your file flash.off is triangulated, but quite difficult to mesh: it has two cylindrical patches of surface that are very close from each other. It means that the least feature size of this surface
is very small. You need to decrease the sizing field by a magnitude. However, I agree there is a problem in the surface mesher, because I have not been able to mesh that object without the assertion. Again, I
know that the problematic feature is the coplanar facets at the bottom of the object. We have solutions for that, but the merge with the branch of CGAL-3.6 is not easy.
Laurent Rineau, PhD
- [cgal-discuss] remeshing crash: a problem of the surface mesh generator, fp2008, 05/21/2010
- Re: [cgal-discuss] remeshing crash: a problem of the surface mesh generator, Andreas Fabri, 05/21/2010
- [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, fp2008, 05/21/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Laurent Rineau (GeometryFactory), 05/25/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Joe C, 05/25/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Joe C, 05/27/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Stephane Tayeb, 05/27/2010
