cgal-discuss - Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator
  • To:
  • Subject: Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator
  • Date: Thu, 27 May 2010 08:51:17 +0200
Joe C wrote:
Just one more question on the third template parameter 'Dummy_kernel'. I
cannot see it is really used anywhere in the code. So why would changing it
from Simple_cartesian_kernel to IGT solve the first issue when remeshing the
cube?
template <class Polyhedron, class Kernel, class Dummy_kernel>
class AABB_polyhedral_oracle : public Polyhedron
Joe
please correct me if there is anything I missed:
Hi,
You are right. The following typedefs should be used (where Dummy_ could be any type):
typedef CGAL::Mesh_3::Robust_intersection_traits_3<Kernel> IGT;
typedef CGAL::AABB_polyhedral_oracle<Polyhedron,IGT,Dummy_> Input_surface;
Best regards,
Stéphane.
On Tue, May 25, 2010 at 2:48 AM, Laurent Rineau (GeometryFactory) <
wrote:
On Friday 21 May 2010 09:27:10 fp2008 wrote:
Hi Andreas,
I attached three OFF files. The remeshing tool crashes quickly when
processing box.off and glass-mug.off, though it gets stuck instead with
flash.off.
There are several issues.
** First, there is a non-exact use of the AABB_tree class, in the
Polyhedron demo. Please apply the following patch:
--- demo/Polyhedron/Polyhedron_demo_remeshing_plugin_cgal_code.cpp.~BASE~
2010-05-25 11:24:12.000000000 +0200
+++ demo/Polyhedron/Polyhedron_demo_remeshing_plugin_cgal_code.cpp
2010-05-21 15:12:43.000000000 +0200
@@ -110,10 +110,10 @@
// Types for meshing
-typedef CGAL::Simple_cartesian<double> Simple_cartesian_kernel;
+// typedef CGAL::Simple_cartesian<double> Simple_cartesian_kernel;
// input surface
-// typedef CGAL::Mesh_3::Robust_intersection_traits_3<Kernel> IGT;
-typedef
CGAL::AABB_polyhedral_oracle<Polyhedron,Kernel,Simple_cartesian_kernel>
Input_surface;
+typedef CGAL::Mesh_3::Robust_intersection_traits_3<Kernel> IGT;
+typedef CGAL::AABB_polyhedral_oracle<Polyhedron,Kernel,IGT> Input_surface;
// A base non-templated class, to allow
That will prevent the Surface_mesher from crashing on a simple cube
surface. Actually, a cube a something particularly difficult to mesh:
- there are a lot of coplanar points,
- there are sharp edges (that the Surface_mesher package cannot mesh
properly).
** Second, your file glass-mug.off is not a triangulated surface. Please
use the menu entry Operations->Triangulate facets before launching the
remeshing function.
** Third, your file flash.off is triangulated, but quite difficult to mesh:
it has two cylindrical patches of surface that are very close from each
other. It means that the least feature size of this surface
is very small. You need to decrease the sizing field by a magnitude.
However, I agree there is a problem in the surface mesher, because I have
not been able to mesh that object without the assertion. Again, I
know that the problematic feature is the coplanar facets at the bottom of
the object. We have solutions for that, but the merge with the branch of
CGAL-3.6 is not easy.
Laurent Rineau, PhD
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
