- To:
- Subject: Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3
- Date: Thu, 08 Jul 2010 09:08:58 +0200
Sorry but I still don't get your point.
The activation of the plane support is done within a class model of PolyhedronItems_3.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Concept_PolyhedronItems_3.html#Cross_link_anchor_1096
Can you please state clearly what you would like to do.
S.
Mohamed Yousef wrote:
simply if you want to use it as usual to extend a kernel by adding plane support , you will lack all additional things the kernel provides
the way for this to go (done in other traits , every where in cgal ) is to inherit from specializing kernel , thus you have your kernel with additional support of plane
Regards,
Mohamed Yousef
On 8 July 2010 08:52, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
Hello,
i think the class "Polyhedron_traits_with_normals_3" should
inherit from Kernel_
Thanks,
Reading the documentation I see no reason why it should.
The concept PolyhedronTraits_3 is quite simple and
Polyhedron_traits_with_normals_3 seems to be a model of it.
What leads you to think there is a bug?
S.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/07/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Sebastien Loriot (GeometryFactory), 07/08/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/08/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Mohamed Yousef, 07/13/2010
- Re: [cgal-discuss] [Bug] Polyhedron_traits_with_normals_3, Sebastien Loriot (GeometryFactory), 07/13/2010
