cgal-discuss - [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent."
  • To:
  • Subject: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent."
  • Date: Mon, 19 Jul 2010 16:06:57 +0200 (CEST)
Hi! I'm very new to CGAL, so please forgive any cluelessness. I'm on Mac
OS
X 10.6.3 using CGAL version 5.0.0 I think (my /opt/local/lib/libCGAL.dylib
points to libCGAL.5.0.0.dylib), installed using MacPorts. I'm trying to use
the Delaunay_d class to do Delaunay triangulations. I'm wrapping the calls in
R and am calling them through R's .C() calling interface. I don't think
that's
particularly relevant to my problem, though, so let's not get too lost in the
details. Test runs that I did with this wrapping worked fine, but now that
I'm
trying to use the code with my actual dataset, the problem is that I'm getting
an assertion from function_objectsCd.h:285 when I insert a particular point
into the data structure; the assert is "Contained_in_simplex_d: A not affinely
independent." I have no idea what that means, or how to fix it. Here's the
sequence of (four-dimensional) points I'm inserting:
0, 0, 0, 0
0.25, 0.00, 0.00, 100.00
0.5, 0.0, 0.0, 0.0
0.75, 0.00, 0.00, 0.00
1, 0, 0, 0
0.00, 0.25, 0.00, 100.00
1.00, 0.25, 0.00, 0.00
0.0, 0.5, 0.0, 100.0
1.0, 0.5, 0.0, 0.0
0.00, 0.75, 0.00, 100.00
1.00, 0.75, 0.00, 100.00
0, 1, 0, 0
0.25, 1.00, 0.00, 100.00
0.5, 1.0, 0.0, 0.0
The insertion of the last point in that list triggers the assertion.
I've previously been working with only 2D points, and so the R library
deldir
sufficed for my purposes. I never hit this sort of issue with it; it would
accept pretty much any set of points I cared to give it. Does CGAL's
Delaunay_d class have more stringent requirements for the points you are
allowed to supply it, and if so, why? The points I want to feed into it are
generated algorithmically, so it's quite a bummer if the Delaunay_d algorithm
is going to fail unpredictably for some sequences of points that I try to give
it! Is there anything I can do about this?
Here's the wrapper functions I've defined to interface with R; currently
they
work with a global Delaunay_d object:
static Delaunay_d *T;
extern "C"
// Initialize the state of this package; discard all previous state
// d_ <- the number of dimensions this triangulation
will involve
void init(const int *d_)
using ::T;
if (T)
delete T;
T = new Delaunay_d(*d_);
// Insert a new point in the triangulation
// x <- a vector of coordinates for one n-dimensional
point
void insert(double *x)
using ::T;
int d = T->dimension();
T->insert(Point(d, x, x+d));
and here are the relevant R functions:
cgal_delaunay_init <- function(dimensions, debug=FALSE)
# check that we are non initialized
stopifnot(!exists("cgal_delaunay_dims"))
# note this must load the debug build; the release build fails!
dyn.load("/Users/bhaller/objects/Debug/libcgaldelaunay.dylib")
# test that the functions we expect to be there are there
stopifnot(is.loaded("init", PACKAGE="libcgaldelaunay.dylib"))
stopifnot(is.loaded("insert", PACKAGE="libcgaldelaunay.dylib"))
# test that the number of dimensions is reasonable
stopifnot(NROW(dimensions) == 1)
stopifnot(dimensions >= 2)
stopifnot(dimensions <= 32)
cgal_delaunay_debug <<- debug
# initialize with the given number of dimensions
if (cgal_delaunay_debug)
print(paste("initializing cgal_delaunay with dimensions ==",
dimensions))
result <- .C("init", n=as.integer(dimensions),
stopifnot(result$n == as.integer(dimensions))
# remember the number of dimensions, for our own bookkeeping
cgal_delaunay_dims <<- dimensions
cgal_delaunay_insert <- function(x)
# check that we are initialized
stopifnot(exists("cgal_delaunay_dims"))
stopifnot(is.vector(x))
stopifnot(NROW(x) == cgal_delaunay_dims)
print(paste("inserting point (", paste(x, collapse=", "), ")",
sep=""))
result <- .C("insert", x=as.double(x),
As I said before, I don't think this wrapping is related to the problem; I
think that a test program that just inserted the points in question would hit
the assertion, but I haven't tested that.
Thanks!
Ben Haller
McGill University
