cgal-discuss - Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent."
  • To:
  • Subject: Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent."
  • Date: Wed, 21 Jul 2010 10:46:58 +0200
Sebastien Loriot (GeometryFactory) wrote:
Ben Haller wrote:
On Jul 21, 2010, at 10:23 AM, Sebastien Loriot (GeometryFactory) wrote:
Ben Haller wrote:
Yeah, I think you're right. I'm puzzled as to why using exact numbers would solve the problem; the points in question violate the assumption (that 3+ points will not be colinear) even with exact numbers, I would think. But anyhow, I have come to the conclusion that jittering the points slightly is a reasonable workaround; I often have colinear points, and I don't really care which way the Delaunay triangulation decides to handle them, as long as it picks a way and doesn't raise. :->
Thanks!
The problem here is not which triangulation you will get but
will you get a triangulation. Due to floating point computation,
you end up in a situation (because another predicate was badly
evaluated) where you call a predicate with points that
should form an independent set of points. Unfortunately this is not the
case and the predicate crashes.
I see. Whereas with exact numbers, the first predicate is evaluated exactly, and that leads to the avoidance of the second predicate...? Well, jittering seems to be working for me so far as a workaround, but if this ever happens to me again, I'll switch to the exact number type. Thanks!
Ben Haller
McGill University
If no construction are required, an alternative may be
using Exact_predicates_inexact_constructions_kernel.
which is not working in d-dimension...
sorry, my answer is correct for 2D and 3D only.
S.
PS: Please answer to the list, the discussion may be useful to other people.
