cgal-discuss - Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent."
  • To:
  • Subject: Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent."
  • Date: Wed, 21 Jul 2010 10:43:01 +0200
Ben Haller wrote:
On Jul 21, 2010, at 10:23 AM, Sebastien Loriot (GeometryFactory) wrote:
Ben Haller wrote:
Yeah, I think you're right. I'm puzzled as to why using exact numbers would
solve the problem; the points in question violate the assumption (that 3+ points
will not be colinear) even with exact numbers, I would think. But anyhow, I
have come to the conclusion that jittering the points slightly is a reasonable
workaround; I often have colinear points, and I don't really care which way the
Delaunay triangulation decides to handle them, as long as it picks a way and
doesn't raise. :->
Thanks!
The problem here is not which triangulation you will get but
will you get a triangulation. Due to floating point computation,
you end up in a situation (because another predicate was badly
evaluated) where you call a predicate with points that
should form an independent set of points. Unfortunately this is not the
case and the predicate crashes.
I see. Whereas with exact numbers, the first predicate is evaluated
exactly, and that leads to the avoidance of the second predicate...? Well,
jittering seems to be working for me so far as a workaround, but if this ever
happens to me again, I'll switch to the exact number type. Thanks!
Ben Haller
McGill University
If no construction are required, an alternative may be
using Exact_predicates_inexact_constructions_kernel.
S.
PS: Please answer to the list, the discussion may be useful to other people.
