Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent."
- To:
- Subject: Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent."
- Date: Wed, 21 Jul 2010 10:23:56 +0200
Ben Haller wrote:
Yeah, I think you're right. I'm puzzled as to why using exact numbers wouldThe problem here is not which triangulation you will get but
solve the problem; the points in question violate the assumption (that 3+ points
will not be colinear) even with exact numbers, I would think. But anyhow, I
have come to the conclusion that jittering the points slightly is a reasonable
workaround; I often have colinear points, and I don't really care which way the
Delaunay triangulation decides to handle them, as long as it picks a way and
doesn't raise. :->
Thanks!
will you get a triangulation. Due to floating point computation,
you end up in a situation (because another predicate was badly
evaluated) where you call a predicate with points that
should form an independent set of points. Unfortunately this is not the
case and the predicate crashes.
S.
Ben Haller
McGill University
On Jul 20, 2010, at 10:06 AM, Sebastien Loriot (GeometryFactory) wrote:
Ben Haller wrote:
On Jul 19, 2010, at 4:06 PM, Ben Haller wrote:Hello,
Hi! I'm very new to CGAL, so please forgive any cluelessness. I'm on Mac OSI have just discovered that adding a small amount of random noise to the
X 10.6.3 using CGAL version 5.0.0 I think (my /opt/local/lib/libCGAL.dylib
points to libCGAL.5.0.0.dylib), installed using MacPorts. I'm trying to use
the Delaunay_d class to do Delaunay triangulations. I'm wrapping the calls in
R and am calling them through R's .C() calling interface. I don't think
that's
particularly relevant to my problem, though, so let's not get too lost in the
details. Test runs that I did with this wrapping worked fine, but now that
I'm
trying to use the code with my actual dataset, the problem is that I'm getting
an assertion from function_objectsCd.h:285 when I insert a particular point
into the data structure; the assert is "Contained_in_simplex_d: A not affinely
independent." I have no idea what that means, or how to fix it...
points I am inserting prevents the assertion. This was based on the
intuition that the problem might be related to some sort of symmetry in the
points inserted. The random noise seems to break the symmetry, and the
assertion is no longer triggered. I'm not happy with this solution, though,
as it seems both to be 1) a hack, and 2) probably unreliable. Does anybody
have a better suggestion? Is there a really good reason why CGAL needs to
assert on this condition in the first place?
Thanks!
Ben Haller
McGill University
I guess this is because your points are in a degenerate configuration
and you are using a non-exact number type. I have the same error you report
when using double, but when using Gmpq this is fine.
Have a look here for more details:
http://www.cgal.org/FAQ.html#inexact_NT
and here:
http://www.cgal.org/philosophy.html
S.
#include <CGAL/Cartesian_d.h>
#include <CGAL/Delaunay_d.h>
#include <CGAL/Gmpq.h>
//typedef CGAL::Cartesian_d<double> Kernel;
typedef CGAL::Cartesian_d<CGAL::Gmpq> Kernel;
typedef CGAL::Delaunay_d<Kernel> Delaunay_d;
typedef Delaunay_d::Point_d Point;
const double points[] = {
0.0, 0.0 , 0.0 , 0.00,
0.25, 0.00, 0.00, 100.00,
0.5, 0.0, 0.0, 0.0, 0.75, 0.00, 0.00, 0.00, 1, 0, 0, 0, 0.00, 0.25, 0.00, 100.00, 1.00, 0.25, 0.00, 0.00, 0.0, 0.5, 0.0, 100.0, 1.0, 0.5, 0.0, 0.0, 0.00, 0.75, 0.00, 100.00, 1.00, 0.75, 0.00, 100.00, 0, 1, 0, 0, 0.25, 1.00, 0.00, 100.00, 0.5, 1.0, 0.0, 0.0
int main()
int d=4;
Delaunay_d T(d);
for (int i=0;i<14;++i)
T.insert(Point(d, points+4*i, points+4*i+d));
return 0;
- [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent.", Ben Haller, 07/19/2010
- Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent.", Ben Haller, 07/19/2010
- Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent.", Sebastien Loriot (GeometryFactory), 07/20/2010
- Message not available
- Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent.", Sebastien Loriot (GeometryFactory), 07/21/2010
- Re: [cgal-discuss] Assertion fail "Contained_in_simplex_d: A not affinely independent.", Ben Haller, 07/21/2010
