- To:
- Subject: Re: [cgal-discuss] How to improve the speed of polygons offsetting in CGAL?
- Date: Mon, 30 Aug 2010 12:28:42 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=goMQejcCUTji3+SAWgQFERT2JIn1TPeDZpcSp3k3rLwiDP86G29uYYK0J/LAKz/69T VMZUtEpsxYWoRmZ10TW+tTZSSzOKaW7p/Ia9yCIiVzg/PvmGQKESbeCgKiTyeq4jWj+1 iAZdirAFUp5ukUmqeGWYj0wSBJAtZ7mizCxIY=
Hi,
Can you try building CGAL and your code with the following macros defined:
_SECURE_SCL=0
NDEBUG
That running time you are reporting looks 10 times slower than it should.
Best
Fernando Cacciola
SciSoft Consulting, Founder
http://www.scisoft-consulting.com
- [cgal-discuss] How to improve the speed of polygons offsetting in CGAL?, 罗恒, 08/28/2010
- Re: [cgal-discuss] How to improve the speed of polygons offsetting in CGAL?, Fernando Cacciola, 08/30/2010
- Re: [cgal-discuss] How to improve the speed of polygons offsetting in CGAL?, Ben Supnik, 08/30/2010
