cgal-discuss - Re: [cgal-discuss] How to improve the speed of polygons offsetting in CGAL?
  • To:
  • Subject: Re: [cgal-discuss] How to improve the speed of polygons offsetting in CGAL?
  • Date: Mon, 30 Aug 2010 11:34:54 -0400
Hi Y'all,
Fernando would be the expert on computation time, but...if the goal is an offset, an alternative to a straight skeleton would be to do a 'buffer' type operation, e.g. construct the offset curves piece-wise, dump them in an arrangement, and use the arrangement to find the interior.
cheers
Ben
Fernando Cacciola wrote:
Hi,
Can you try building CGAL and your code with the following macros defined:
_SECURE_SCL=0
NDEBUG
That running time you are reporting looks 10 times slower than it should.
Best
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
