- To:
- Subject: Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
- Date: Fri, 22 Oct 2010 09:19:11 +0200
Sebastian Kapfer wrote:
Hallo!I will try to see whether this is a bug in CGAL code.
I was able to reproduce that on one of my machines, with your last code+data, with -O1, but not with -O0. It is probably a compiler bug. I do not understand it well.
Weird. I tried with GCC 4.4.3 which is the latest version I can get
my hands at without compiling GCC from source. It's still buggy.
I also tried Intel C++ a minute ago:
$ icpc --version
icpc (ICC) 11.0 20090609
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
Same message, aborts in line 267, even with -O0 and -fp-model strict.
Hm. :-(
In the mean time, I saw in your sample code that you are using a fixed
number of neighbors. If this is the case in your main code,
you can use Orthogonal_k_neighbor_search which will be faster than the incremental version.
S.
- [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/19/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Laurent Rineau (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Laurent Rineau (GeometryFactory), 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/22/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/22/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/25/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/26/2010
