- To:
- Subject: Re: [cgal-discuss] lower bound on element size
- Date: Sun, 05 Dec 2010 12:27:07 +0100
Did you try to weaken the criteria of Delaunay refinement, distance_bound, angular_bound and radius_edge_bound. This may prevent the Delaunay refinement process to overrefine the mesh in some places. Le 02/12/10 11:15, Dominik Szczerba a écrit : Indeed, I am talking about generating tets from segmented images. As I said, I am getting 12 orders of magnitude span in the element sizes, which makes the resulting mesh unsuitable to some computations. In particular, I am running out of numerical precision on such meshes in some cases. Are there practical ways to prevent this from happening? Dominik On Thu, Dec 2, 2010 at 10:44 AM, Laurent Rineau (GeometryFactory) wrote:On Wednesday 01 December 2010 22:00:45 Dominik Szczerba wrote:Hi I need to impose LOWER bound on element size. According to the latest documentaiton: the radius bound: This parameter controls the size (edge length) of mesh cells. Actually, it is an upper bound on the circumradii of the mesh tetrahedra. I can only provide the UPPER bound. However, in my cases, the smallest generated element is 10 orders of magnitude smaller than the biggest one, resulting in numerical precision problems in subsequent computations. Is there a way to specify the SMALLEST allowed element size or otherwise control its size?My guess is that you are talking about one of the mesh generators of CGAL. Anyway, both the 2D-, surface-,or 3D- mesh generators of CGAL work the same way: you cannot specify a lower bound on the elements sizes. -- Laurent Rineau, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ Release Manager of the CGAL Project http://www.cgal.org/ -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discuss |
- [cgal-discuss] lower bound on element size, Dominik Szczerba, 12/01/2010
- Re: [cgal-discuss] lower bound on element size, Laurent Rineau (GeometryFactory), 12/02/2010
- Re: [cgal-discuss] lower bound on element size, Dominik Szczerba, 12/02/2010
- Message not available
- Re: [cgal-discuss] lower bound on element size, Mariette Yvinec, 12/05/2010
