- To:
- Subject: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?
- Date: Fri, 10 Dec 2010 13:26:28 -0500
Dear CGAL developers,
I'm launching an example based on the code in
examples/Mesh_3/mesh_polyhedral_domain.cpp
but for the parameters that I gave, it seems to take a long time, and
provides no indication on the percent completion.
Can the interface be tweaked to make it more verbose?
Best wishes,
Michel
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
- [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Michel Audette, 12/10/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Laurent Rineau (GeometryFactory), 12/10/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Michel Audette, 12/10/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Mariette Yvinec, 12/10/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Mariette Yvinec, 12/11/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Michel Audette, 12/11/2010
