cgal-discuss - Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?
  • To:
  • Subject: Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?
  • Date: Fri, 10 Dec 2010 19:49:42 +0100
Le vendredi 10 décembre 2010 19:26:28, Michel Audette a écrit :
> Dear CGAL developers,
> I'm launching an example based on the code in
> examples/Mesh_3/mesh_polyhedral_domain.cpp
> but for the parameters that I gave, it seems to take a long time, and
> provides no indication on the percent completion.
> Can the interface be tweaked to make it more verbose?
Define the macro CGAL_MESH_3_VERBOSE to 1. It will not give you the percent
of
completion, because the number of vertices at the end of the meshing process
cannot be guessed, but it will show the size of the internal priority queues.
Laurent Rineau, PhD
