cgal-discuss - Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?
  • To:
  • Subject: Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?
  • Date: Fri, 10 Dec 2010 14:11:52 -0500
Thanks, Laurent.
Seems to work. I'm trying to run the mesh creation with criteria as
follows... I'm seeing a high number of tetrahedra though... Higher
than I'm expecting.
I want high-quality elements of roughly 10mm edges, to begin with. (I
would like 20mm later on if I can).
Does something like this look reasonable? High facet angle, say 45
deg. Facet distance a=10mm. Is the facet size root(3)/4 x a^3 (=43.3),
and the cell size root(2)/12 x a^3 (=117.9)?
Mesh_criteria criteria(facet_angle=45, facet_size=43, facet_distance=10.0,
cell_radius_edge=10.0, cell_size=118);
Does that make sense, or not necessarily. I seem to be getting more
tets "to refine" than I expect.
Michel
On Fri, Dec 10, 2010 at 1:49 PM, Laurent Rineau (GeometryFactory)
wrote:
> Le vendredi 10 décembre 2010 19:26:28, Michel Audette a écrit :
>> Dear CGAL developers,
>> I'm launching an example based on the code in
>> examples/Mesh_3/mesh_polyhedral_domain.cpp
>> but for the parameters that I gave, it seems to take a long time, and
>> provides no indication on the percent completion.
>> Can the interface be tweaked to make it more verbose?
> Define the macro CGAL_MESH_3_VERBOSE to 1. It will not give you the percent
> of
> completion, because the number of vertices at the end of the meshing process
> cannot be guessed, but it will show the size of the internal priority
> queues.
> Laurent Rineau, PhD
> Release Manager of the CGAL Project       http://www.cgal.org/
> R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
