- To:
- Subject: Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?
- Date: Fri, 10 Dec 2010 16:23:19 -0500
Hi Mariette,
thanks for your kind reply. I'll try it your way. Do the other
parameters appear reasonable?
Best wishes,
Michel
On Fri, Dec 10, 2010 at 4:14 PM, Mariette Yvinec
wrote:
> your facet angle is too high. It is suppose to be
> a lower bound for the minimum angle of each facet.
> A reasonable value is between 20 and 30 degree.
> Michel Audette wrote:
> Thanks, Laurent.
> Seems to work. I'm trying to run the mesh creation with criteria as
> follows... I'm seeing a high number of tetrahedra though... Higher
> than I'm expecting.
> I want high-quality elements of roughly 10mm edges, to begin with. (I
> would like 20mm later on if I can).
> Does something like this look reasonable? High facet angle, say 45
> deg. Facet distance a=10mm. Is the facet size root(3)/4 x a^3 (=43.3),
> and the cell size root(2)/12 x a^3 (=117.9)?
> Mesh_criteria criteria(facet_angle=45, facet_size=43, facet_distance=10.0,
> cell_radius_edge=10.0, cell_size=118);
> Does that make sense, or not necessarily. I seem to be getting more
> tets "to refine" than I expect.
> Michel
> On Fri, Dec 10, 2010 at 1:49 PM, Laurent Rineau (GeometryFactory)
> wrote:
> Le vendredi 10 décembre 2010 19:26:28, Michel Audette a écrit :
> Dear CGAL developers,
> I'm launching an example based on the code in
> examples/Mesh_3/mesh_polyhedral_domain.cpp
> but for the parameters that I gave, it seems to take a long time, and
> provides no indication on the percent completion.
> Can the interface be tweaked to make it more verbose?
> Define the macro CGAL_MESH_3_VERBOSE to 1. It will not give you the percent
> of
> completion, because the number of vertices at the end of the meshing process
> cannot be guessed, but it will show the size of the internal priority
> queues.
> Laurent Rineau, PhD
> Release Manager of the CGAL Project http://www.cgal.org/
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Mariette Yvinec
> Geometrica project team
> INRIA Sophia-Antipolis
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
- [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Michel Audette, 12/10/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Laurent Rineau (GeometryFactory), 12/10/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Michel Audette, 12/10/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Mariette Yvinec, 12/10/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Mariette Yvinec, 12/11/2010
- Re: [cgal-discuss] is it possible to make make_mesh_3 indicate % completion?, Michel Audette, 12/11/2010
