- To:
- Subject: Re: [cgal-discuss] compiling CGAL in windows
- Date: Mon, 10 Jan 2011 11:50:43 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=kV50Rr96px1A0bZuULkFDVTNAiasgNP9tTV/Q61fxuVZ9yx2tgjxkpY5IrFOlE6yPB c6EGun7cmD2cS3eIZOsWqbRLGbwOJLwhqA7LSK0VPl8MPyujyXBPgiTJlKZXH/4pV62s ysdZ+qrqiG84AMTj92fGQOOtH+ngKwXw/9qAI=
Hello,
I downloaded CGAL-3.7-Setup.exe and ran it.
Is there another file called CGAL.exe?
Thanks,
Dror
On Sat, Jan 8, 2011 at 9:31 PM, H-B <> wrote:
Hi Drorsh,Did you download CGAL.exe for windows?
--- On Sat, 1/8/11, drorsh <> wrote:
Subject: [cgal-discuss] compiling CGAL in windows
To:
Date: Saturday, January 8, 2011, 7:05 AM
Hello,
I am a total newbie to CGAL, and this is actually the first time I'm tryint
to use C++ on my private computer (I am using visual studio 9.0, installed
on Windows 7).
I am trying to follow the instructions in the installation guide, but have
problems right on start.
When I get to the part of "Configuring CGAL" and try to either use
cmake-gui, or simply type "cmake ." in the command line (under the correct
directory of course), I get a long list of errors, the first one being:
-- Building for: NMake Makefiles
CMake Error at C:/Program Files (x86)/CMake
2.8/share/cmake-2.8/Modules/CMakeDet
ermineSystem.cmake:157 (FILE):
file Internal CMake error when trying to open file: C:/Program Files
(x86)/CGAL-3.7/CMakeFiles/CMakeOutput.log for writing.
Call Stack (most recent call first):
CMakeLists.txt:6 (project)
CMake Error: Could not open file for write in copy operation C:/Program
Files (x
86)/CGAL-3.7/CMakeFiles/CMakeSystem.cmake.tmp
CMake Error: : System Error: No such file or directory
ermineSystem.cmake:169 (CONFIGURE_FILE):
configure_file Problem configuring file
And this goes on and on.
Previous to trying to do this I downloaded and installed visual studio 9,
downloaded cmake and boost. I also ran a simple program in visual studio 9
just to see that everything works correctly.
I'd appreciate any help.
Thanks!
Dror
View this message in context: http://cgal-discuss.949826.n4.nabble.com/compiling-CGAL-in-windows-tp3204916p3204916.html
- [cgal-discuss] compiling CGAL in windows, drorsh, 01/08/2011
- Re: [cgal-discuss] compiling CGAL in windows, H-B, 01/08/2011
- Re: [cgal-discuss] compiling CGAL in windows, dror shemesh, 01/10/2011
- Re: [cgal-discuss] compiling CGAL in windows, Laurent Saboret, 01/10/2011
- Re: [cgal-discuss] compiling CGAL in windows, Pablo Fernández Cuadros, 01/11/2011
- [cgal-discuss] Re: compiling CGAL in windows, drorsh, 01/12/2011
- Re: [cgal-discuss] Re: compiling CGAL in windows, Laurent Saboret, 01/12/2011
- Re: [cgal-discuss] Re: compiling CGAL in windows, Laurent Rineau (GeometryFactory), 01/12/2011
- Re: [cgal-discuss] Re: compiling CGAL in windows, Pablo Fernández Cuadros, 01/12/2011
- [cgal-discuss] Re: compiling CGAL in windows, drorsh, 01/29/2011
- Re: [cgal-discuss] Re: compiling CGAL in windows, H-B, 01/30/2011
- Re: [cgal-discuss] Re: compiling CGAL in windows, H-B, 01/12/2011
