- To:
- Subject: [cgal-discuss] point location/interpolation on a 2d mesh
- Date: Fri, 21 Jan 2011 15:24:55 -0500
Hello,
Hello I would like to calculate interpolated values from vertices on a 2d mesh.
My problem is as follows:
- I have a mesh given by vertices and constraints (i know the boundary and the partitioning of the space (holes) )
- With this information i would like to create a cgal mesh to perform interpolation operations of lets say the velocity field stored in the
vertices.
I saw the cgal interpolation page and the point location page for the triangulation.
Is it also possible to use the triangulation hierarchy on a mesh for efficient point location.
I need a mesh to determine what is inside and what is outside as the domain has holes or is there a simpler way to perform interpolation/and determining inside/outside like in the mesh case.
Thank you very much
hj
- [cgal-discuss] point location/interpolation on a 2d mesh, Hansjoerg Seybold, 01/21/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Sebastien Loriot (GeometryFactory), 01/24/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Hansjoerg Seybold, 01/24/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Sebastien Loriot (GeometryFactory), 01/25/2011
