- To:
- Subject: Re: [cgal-discuss] point location/interpolation on a 2d mesh
- Date: Tue, 25 Jan 2011 08:03:58 +0100
Hansjoerg Seybold wrote:
Hi,Define a constrained triangulation with hierarchy
that were the two options which i was thinking of.
I dont care too much about the actual mesh structure of the triangulation,
only about the vertices as they store the data for the (later) interpolation,
so also remeshing would be fine for me if i could get the values for the
"new points" somehow (also some kind fo interpolation i suppose).
How would i use the triangulation hirarchy in the mesh_2? for efficient point
location.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_35.10
use refine_Delaunay_mesh:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_2_ref/Function_refine_Delaunay_mesh_2.html#Cross_link_anchor_1438
Note that you will need to use CGAL::Delaunay_mesh_face_base_2 as face
in your triangulation:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_2_ref/Class_Delaunay_mesh_face_base_2.html#Cross_link_anchor_1429
you can also only use a constrained triangulation to have a "minimal"
mesh.
S.
Thank you very much for your help
hj
You cannot use directly Delaunay_triangulation as your input mesh is
probably not Delaunay.
A solution is to use Triangulation_2 and
Triangulation_data_structure_2 but it may be tricky to
make a copy of your mesh (mimicking the function copy_tds
in CGAL/Triangulation_data_structure_2 is probably the easiest way).
To add a tag into faces see:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_face_base_with_info_2.html
Another alternative if remeshing is acceptable for your application
is to use Mesh_2 with constrained edges and excluded parts (see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_2/Chapter_main.html)
S.
cheers hj
On Mon, Jan 24, 2011 at 9:31 AM, Sebastien Loriot
(GeometryFactory) <sloriot.ml <http://sloriot.ml>
<http://sloriot.ml>@gmail.com <http://gmail.com>
Hello,
Hello I would like to calculate interpolated values from
vertices on a 2d mesh.
My problem is as follows:
- I have a mesh given by vertices and constraints (i know the
boundary and the partitioning of the space (holes) )
- With this information i would like to create a cgal
mesh to
perform interpolation operations of lets say the velocity
field
stored in the
vertices.
I saw the cgal interpolation page and the point location page
for the triangulation.
Is it also possible to use the triangulation hierarchy on
a mesh
for efficient point location.
I need a mesh to determine what is inside and what is
outside as
the domain has holes or is there a simpler way to perform
interpolation/and determining inside/outside like in the
mesh case.
Thank you very much
hj
From what I understand, you have a surface mesh with hole
that you
computed (not using CGAL surface mesher) and you want:
1) determine whether a point is on your surface
2) use CGAL::surface_neighbor_coordinates_3 only on points
detected on
your surface
For 1) using AABB_tree and closest_point_and_primitive might help
(http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree/Chapter_main.html#Section_62.6).
Using the triangulation hierarchy will be complicated as you
first need
to have a your surface included into a 3D triangulation.
S.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] point location/interpolation on a 2d mesh, Hansjoerg Seybold, 01/21/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Sebastien Loriot (GeometryFactory), 01/24/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Hansjoerg Seybold, 01/24/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Sebastien Loriot (GeometryFactory), 01/25/2011
