[cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- To:
- Subject: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- Date: Fri, 18 Feb 2011 08:27:00 -0800 (PST)
For these examples, did you have a warning or an error when running cmake ?
Hi Sebastian,
Em.. hard to say, I cannot recall since I re-built cgal so that EXAMPLES are
ON.
I can get the log somewhere of course.. or better I am builting cgal once
more right now and let you know
You said that example are built, but you have no result. What does this
mean? no executable get generated?
yes, no executable
Which platforms, compiler are you using?
I am on on mac os x 10.6.5 with g++ 4.2.1
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Cannot-run-the-examples-for-using-Delaunay-Triangulation-2-whereas-Delaunay-Triangulation-3-runs-fin-tp3313008p3313051.html
- [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Laurent Rineau (GeometryFactory), 02/18/2011
