[cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- To:
- Subject: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- Date: Fri, 18 Feb 2011 08:33:46 -0800 (PST)
I was right..
TAUCS libraries not found. Please specify libraries location.
NOTICE: This directory requires the TAUCS library, and some features will
not be available.
Configuring
/Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Surface_mesh_simplification
example
Configuring
/Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Surface_mesher example
Configuring
/Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Surface_reconstruction_points_3
example
NOTICE: Some of the executables in this directory need the TAUCS library and
will not be compiled.
Configuring
/Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Triangulation_2 example
Configuring
/Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Triangulation_3 example
Configuring
/Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Voronoi_diagram_2
example
Configuring /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Width_3
example
Configuring /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/demo/AABB_tree demo
So TAUCS is the problem.. and now it going to be hell until I install it =D
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Cannot-run-the-examples-for-using-Delaunay-Triangulation-2-whereas-Delaunay-Triangulation-3-runs-fin-tp3313008p3313069.html
- [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Laurent Rineau (GeometryFactory), 02/18/2011
