cgal-discuss - [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation
  • To:
  • Subject: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation
  • Date: Sun, 22 May 2011 17:39:38 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=npZkEEqlYj5iv3UYN50EpZhDzQQUkvIdsSeo9Miblkc4fFLHUuWBuNTHq61QUEnp6Y hxxwzeEVGhHS7hPJrlKQBkT5/U1BrN3nsTq2nQ+uhqC1Gz5H0PCzSiJiFyMwY1KHuV6q ZlLJq3KOO4Pbo3eRFU60cO1oBSfFDggBFPbVY=
Hi,
When i run the following to create Delanuay Triangulation and index of the vertices,
Following error occurs.
error C2039: 'info' : is not a member of 'CGAL::Triangulation_ds_face_base_2<TDS>'
I am new to CGAL. Please help
Brian.
// vertex.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <CGAL/Projection_traits_xy_3.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <fstream>
#include <CGAL/basic.h>
#include <CGAL/Triangulation_face_base_2.h>
#include <CGAL/Triangulation_vertex_base_2.h>
#include <CGAL/Triangulation_vertex_base_with_info_2.h>
#include <CGAL/Triangulation_data_structure_2.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Projection_traits_xy_3<K>  Gt;
typedef K::Point_3   Point;
typedef CGAL::Delaunay_triangulation_2<Gt> CDT;
typedef CGAL::Triangulation_face_base_2<Gt> Fb;
typedef CDT::Finite_faces_iterator Finite_faces_iterator;
typedef CDT::Vertex_handle Vertex_handle;
typedef CDT::Face_handle Face_handle;
typedef int Index;
typedef CGAL::Triangulation_vertex_base_with_info_2<Index, Gt> Info;
int _tmain()
//std::ifstream in("data/terrain.cin");
std::ifstream in("data/test.cin");
std::istream_iterator<Point> begin(in);
std::istream_iterator<Point> end;
CDT dt;
dt.insert(begin, end);
// Loop through faces of triangulation and assign index to vertices
int q = 0;
Finite_faces_iterator fvi = dt.finite_faces_begin();
for( ; fvi != dt.finite_faces_end(); ++fvi)
                fvi->info()= q++;
std::cout << dt.number_of_vertices() << std::endl;
std::cout << dt.number_of_faces() << std::endl;
std::cout << dt;
return 0;
