- To:
- Subject: Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation
- Date: Mon, 23 May 2011 11:10:56 +0200
On lundi 23 mai 2011 10:13:33 Brian Sanjeewa Rupasinghe wrote:
> Hi,
> I added this code. But it did not work. I am relatively new to CGAL. Please
> help.
> typedef CGAL::Triangulation_ds_face_base_with_info_2<Index, Gt> Info;
Actually you should use CGAL::Triangulation_face_base_with_info_2<Index,Gt>
but that is the same as far as I know.
My guess is that you did not include the header file that defines that class
template.
Question #1: what is the documentation page of that class?
Answer #1: You can find the link in the reference manual of the
Triangulation_2 package:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Chapter_intro.html
That leads you to:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_face_base_with_info_2.html
Question #2: then, what is the corresponding #include to use.
Answer #2: it is writen in the reference documentation page:
#include <CGAL/Triangulation_face_base_with_info_2.h>
Please, before your next question, try to read the examples and the manual
around. If you ask too many questions whose answers are easy to find in the
CGAL manual, people here will begin to ignore your messages.
Laurent Rineau, PhD
- [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Brian Sanjeewa Rupasinghe, 05/22/2011
- Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Sebastien Loriot (GeometryFactory), 05/23/2011
- Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Brian Sanjeewa Rupasinghe, 05/23/2011
- Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Samuel Hornus, 05/23/2011
- Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Laurent Rineau (GeometryFactory), 05/23/2011
