cgal-discuss - Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation
  • Date: Mon, 23 May 2011 10:34:00 +0200
Cross-posts.
Samuel is right except that you need to replace 3.3 by latest in the given links.
S.
Samuel Hornus wrote:
Hi Brian,
Please read the CGAL User Manual for 2D triangulations:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html
Please read it entirely. You must read it entirely, because it's not so easy
to grasp and reading it all makes it smoother.
Done?
Then you may have found a solution to your problem. If not, it's there:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_25.11
Now, take some time as well to skim over this:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2_ref/Chapter_intro.html
By that time, you should find yourself in Treaven, the heaven for
triangulations.
