- To:
- Subject: Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation
- Date: Mon, 23 May 2011 10:32:49 +0200
Hi Brian,
Please read the CGAL User Manual for 2D triangulations:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html
Please read it entirely. You must read it entirely, because it's not so easy
to grasp and reading it all makes it smoother.
Done?
Then you may have found a solution to your problem. If not, it's there:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_25.11
Now, take some time as well to skim over this:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2_ref/Chapter_intro.html
By that time, you should find yourself in Treaven, the heaven for
triangulations.
sam
On May 23, 2011, at 10:13 AM, Brian Sanjeewa Rupasinghe wrote:
> Hi,
> I added this code. But it did not work. I am relatively new to CGAL. Please
> help.
> typedef CGAL::Triangulation_ds_face_base_with_info_2<Index, Gt> Info;
> Brian.
- [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Brian Sanjeewa Rupasinghe, 05/22/2011
- Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Sebastien Loriot (GeometryFactory), 05/23/2011
- Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Brian Sanjeewa Rupasinghe, 05/23/2011
- Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Samuel Hornus, 05/23/2011
- Re: [cgal-discuss] Creating Indices for vertices in Delanuay Triangulation, Laurent Rineau (GeometryFactory), 05/23/2011
