- To:
- Subject: [cgal-discuss] Re: Contrain faces within a 3d triangulation
- Date: Fri, 27 May 2011 08:48:46 -0700 (PDT)
Olivier Devillers-2 wrote:
> Assume that you can constrain a face then you necessarily constrain its
> edges.
On the other hand, if you can constrain edges, then constrain all the edges
of the Schönhardt polyhedron and you have constrained its faces…
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Contrain-faces-within-a-3d-triangulation-tp3555239p3555691.html
- [cgal-discuss] Contrain faces within a 3d triangulation, Yohann, 05/27/2011
- Re: [cgal-discuss] Contrain faces within a 3d triangulation, Olivier Devillers, 05/27/2011
- [cgal-discuss] Re: Contrain faces within a 3d triangulation, Yohann, 05/27/2011
- Re: [cgal-discuss] Re: Contrain faces within a 3d triangulation, Olivier Devillers, 05/27/2011
- Re: [cgal-discuss] Re: Contrain faces within a 3d triangulation, Olivier Devillers, 05/28/2011
- [cgal-discuss] Re: Contrain faces within a 3d triangulation, Yohann, 05/30/2011
- Re: [cgal-discuss] Re: Contrain faces within a 3d triangulation, Olivier Devillers, 05/30/2011
