- To:
- Subject: Re: [cgal-discuss] Re: Contrain faces within a 3d triangulation
- Date: Sat, 28 May 2011 00:33:33 +0200
Le 5/27/11 5:48 PM, Yohann a écrit :
Olivier Devillers-2 wrote:no
Assume that you can constrain a face then you necessarily constrain itsOn the other hand, if you can constrain edges, then constrain all the edges
edges.
of the Schönhardt polyhedron and you have constrained its faces…
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Contrain-faces-within-a-3d-triangulation-tp3555239p3555691.html
- [cgal-discuss] Contrain faces within a 3d triangulation, Yohann, 05/27/2011
- Re: [cgal-discuss] Contrain faces within a 3d triangulation, Olivier Devillers, 05/27/2011
- [cgal-discuss] Re: Contrain faces within a 3d triangulation, Yohann, 05/27/2011
- Re: [cgal-discuss] Re: Contrain faces within a 3d triangulation, Olivier Devillers, 05/27/2011
- Re: [cgal-discuss] Re: Contrain faces within a 3d triangulation, Olivier Devillers, 05/28/2011
- [cgal-discuss] Re: Contrain faces within a 3d triangulation, Yohann, 05/30/2011
- Re: [cgal-discuss] Re: Contrain faces within a 3d triangulation, Olivier Devillers, 05/30/2011
