- To: "" <>
- Subject: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib'
- Date: Mon, 6 Jun 2011 22:37:37 +0800 (CST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.cn; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=ZGRRVriZOX+Xre+Im5Kr5UdWlPnqIFEcCY+B29SUOu/+bzvQ+uzOh3kj+3xZ4oE+rd04fwACHQlDrC0gTEQPUTZT+p1Wi0vW1O9n1nAXRax8urf0XBn7BoK4fo5D6ejyvIQr+NLd8RO64o+hvKJ/ByhV3WMrsHXAoM+AjBwMpEU=;
Hi, Loriot
First, thank you for your reply to my question:"Cannot open include file: 'CGAL/compiler_config.h': No such file or directory". Now I have resolved it.
But when I try to build the Polygon example in a VS10 win32 project, there's an error saying the "library CGAL-vc100-mt-gd.lib" was not found.
Would you have any suggestions?
Thanks,
Sanchrist
发件人: Sebastien Loriot (GeometryFactory) <>
收件人:
发送日期: 2011年6月6日, 星期一, 下午 2:59
主题: Re: [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory
吴三子 wrote:
> Hi, everyone
> I have successfully installed the CGAL on my machine, and I's using Windows XP OS.
> I also have included the correct include folder under VC++ directory but still I get the error.
> My e-mail is
> Waiting for reply.
> Thanks, Sanchrist
This file is generated by the cmake configuration procedure of the CGAL
library. It is located in include/CGAL where you configured and compiled
CGAL. Using cmake to generate a solution should add this path
automatically to your include path.
S.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory, 吴三子, 06/06/2011
- Re: [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory, Sebastien Loriot (GeometryFactory), 06/06/2011
- 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', 吴三子, 06/06/2011
- Re: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', Andreas Fabri, 06/06/2011
- 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', 吴三子, 06/07/2011
- Re: 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', Laurent Rineau (GeometryFactory), 06/07/2011
