- To:
- Subject: Re: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib'
- Date: Mon, 06 Jun 2011 16:40:09 +0200
Hello,
You probably only built the release and not the debug version
of CGAL.
andreas
On 06/06/2011 16:37, 吴三子 wrote:
Hi, Loriot
First, thank you for your reply to my question:"Cannot open include
file: 'CGAL/compiler_config.h': No such file or directory". Now I have
resolved it.
But when I try to build the Polygon example in a VS10 win32 project,
there's an error saying the "library CGAL-vc100-mt-gd.lib" was not found.
Would you have any suggestions?
Thanks,
Sanchrist
*发件人:* Sebastien Loriot (GeometryFactory)
*收件人:*
*发送日期:* 2011年6月6日, 星期一, 下午 2:59
*主题:* Re: [cgal-discuss] Cannot open include file:
吴三子 wrote:
> Hi, everyone
> I have successfully installed the CGAL on my machine, and I's using
Windows XP OS.
> I also have included the correct include folder under VC++ directory
but still I get the error.
> My e-mail is
<mailto:>
> Waiting for reply.
> Thanks, Sanchrist
This file is generated by the cmake configuration procedure of the CGAL
library. It is located in include/CGAL where you configured and compiled
CGAL. Using cmake to generate a solution should add this path
automatically to your include path.
S.
-- You are currently subscribed to cgal-discuss.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory, 吴三子, 06/06/2011
- Re: [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory, Sebastien Loriot (GeometryFactory), 06/06/2011
- 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', 吴三子, 06/06/2011
- Re: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', Andreas Fabri, 06/06/2011
- 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', 吴三子, 06/07/2011
- Re: 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', Laurent Rineau (GeometryFactory), 06/07/2011
