- To:
- Subject: Re: 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib'
- Date: Tue, 7 Jun 2011 11:17:36 +0200
On mardi 07 juin 2011 04:25:34 吴三子 wrote:
> Hi, andreas
> I built not only the debug but also the release version, and the same error
> will happen again. Would you have any other suggestions?
Its seems your project has not been created using CMake. In your project, in
Linker->General, you must add the path to the directory where CGAL libraries
have been created to the list of paths in the item "Additional libraries
paths".
Laurent Rineau, PhD
- [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory, 吴三子, 06/06/2011
- Re: [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory, Sebastien Loriot (GeometryFactory), 06/06/2011
- 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', 吴三子, 06/06/2011
- Re: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', Andreas Fabri, 06/06/2011
- 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', 吴三子, 06/07/2011
- Re: 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', Laurent Rineau (GeometryFactory), 06/07/2011
