- To: "" <>
- Subject: 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib'
- Date: Tue, 7 Jun 2011 10:25:34 +0800 (CST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.cn; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=g0S23piIHPDWe407CqlGyLQFqZ9iacQGEkpAVsqoEtVn+CgfW+aRBZmJccdYW3Ak5Ryb9NgOlXEgpSQFBGxYAyRVVn0oKzAjT/TCExsDg+hBNnkYbGF4tcttiwxm8O7IADovA8EkigAT1H+USM5g0f7HGaWf80ah6V2qrJrVgPA=;
Hi, andreas
I built not only the debug but also the release version, and the same error will happen again.
Would you have any other suggestions?
Thanks,
Sanchrist
发件人: Andreas Fabri <>
收件人:
发送日期: 2011年6月6日, 星期一, 下午 10:40
主题: Re: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib'
Hello,
You probably only built the release and not the debug version
of CGAL.
andreas
On 06/06/2011 16:37, 吴三子 wrote:
> Hi, Loriot
> First, thank you for your reply to my question:"Cannot open include
> file: 'CGAL/compiler_config.h': No such file or directory". Now I have
> resolved it.
> But when I try to build the Polygon example in a VS10 win32 project,
> there's an error saying the "library CGAL-vc100-mt-gd.lib" was not found.
> Would you have any suggestions?
> Thanks,
> Sanchrist
> *发件人:* Sebastien Loriot (GeometryFactory) <>
> *收件人:*
> *发送日期:* 2011年6月6日, 星期一, 下午 2:59
> *主题:* Re: [cgal-discuss] Cannot open include file:
> 吴三子 wrote:
> > Hi, everyone
> > I have successfully installed the CGAL on my machine, and I's using
> Windows XP OS.
> > I also have included the correct include folder under VC++ directory
> but still I get the error.
> > My e-mail is <mailto:>
> > Waiting for reply.
> > Thanks, Sanchrist
> This file is generated by the cmake configuration procedure of the CGAL
> library. It is located in include/CGAL where you configured and compiled
> CGAL. Using cmake to generate a solution should add this path
> automatically to your include path.
> S.
> -- You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory, 吴三子, 06/06/2011
- Re: [cgal-discuss] Cannot open include file: 'CGAL/compiler_config.h': No such file or directory, Sebastien Loriot (GeometryFactory), 06/06/2011
- 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', 吴三子, 06/06/2011
- Re: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', Andreas Fabri, 06/06/2011
- 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', 吴三子, 06/07/2011
- Re: 回复: 回复: [cgal-discuss] cannot open file 'CGAL-vc100-mt-gd.lib', Laurent Rineau (GeometryFactory), 06/07/2011
