- To:
- Subject: Re: [cgal-discuss] cutting the peanut in half: thin elements
- Date: Mon, 20 Jun 2011 21:35:00 +0200
Hi Michel,
Some days ago we found a bug in the code that removes slivers.
The workaround is to define the macro
CGAL_MESH_3_USE_RELAXED_HEAP
Can you report back if it helped in your case.
andreas
On 20/06/2011 20:58, Michel Audette wrote:
Dear CGAL developers,
In the past week or so, I've become interested in the new capacity of
3.8 to offer boundary-faithful and controlled-resolution tetrahedralization.
Returning to the example in
examples/Mesh_3/mesh_two_implicit_spheres_with_balls.cpp,
playing with the mesh size a little bit,
Mesh_criteria criteria(edge_size = 0.5,
facet_angle = 25, facet_size = 0.5,
cell_radius_edge_ratio = 2, cell_size = 0.5);
c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria,
odt(time_limit=30),
perturb(sliver_bound=10,
time_limit=30),
exude(time_limit=30,
sliver_bound=15));
and visualizing the interior with Paraview (by producing a vtk file),
vtkSmartPointer<vtkUnstructuredGrid>
outputUnstructuredGrid = vtkSmartPointer<vtkUnstructuredGrid>::New();
CGAL::output_c3t3_to_vtk_unstructured_grid(c3t3, outputUnstructuredGrid);
outputUnstructuredGrid->Squeeze();
vtkSmartPointer<vtkUnstructuredGridWriter> writer =
vtkSmartPointer<vtkUnstructuredGridWriter>::New();
writer->SetInput(outputUnstructuredGrid);
writer->SetFileName("out.vtk");
writer->Write();
I'm finding nonetheless that some slivers remain in the peanut... See
the enclosed visualization. I'd be happy to help track down the problem.
Is this a parameter of odt(), perturb() or exude() that I am not using
properly?
Best wishes,
Michel
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] cutting the peanut in half: thin elements, Michel Audette, 06/20/2011
- Re: [cgal-discuss] cutting the peanut in half: thin elements, Andreas Fabri, 06/20/2011
- Re: [cgal-discuss] cutting the peanut in half: thin elements, Michel Audette, 06/20/2011
- Message not available
- Fwd: [cgal-discuss] cutting the peanut in half: thin elements, Michel Audette, 06/22/2011
- Re: Fwd: [cgal-discuss] cutting the peanut in half: thin elements, Laurent Rineau (GeometryFactory), 06/22/2011
- Re: Fwd: [cgal-discuss] cutting the peanut in half: thin elements, Michel Audette, 06/22/2011
