cgal-discuss - Re: Fwd: [cgal-discuss] cutting the peanut in half: thin elements
  • To:
  • Subject: Re: Fwd: [cgal-discuss] cutting the peanut in half: thin elements
  • Date: Wed, 22 Jun 2011 11:50:40 +0200
On mercredi 22 juin 2011 01:10:06 Michel Audette wrote:
> Hi Andreas,
> playing around with the debugger and the perturbation, as well as
> high-verbosity flag, I'm finding that build_prior_queue returns a null
> pqueue_size in Sliver_perturber.h, and the while loop at line 484 never
> executes, so* nothing gets perturbed..*.
> The output looks like this...
> ./mesh_two_implicit_spheres_with_balls
> Inserting protection balls...
> insert_corners() done. Nb of points in triangulation: 0
> insert_balls_on_edges() done. Nb of points in triangulation: 13
> D vertices.size() 0
> refine_balls() done. Nb of points in triangulation: 13
> Running sliver perturbation...
> Perturb sliver vertices (bound: 1) ...
> Build pqueue...done (0 vertices inserted in 0.01s)
> Legend of the following line: (#vertices in pqueue, #iterations, #fails)
> No perturbation done at this step
> Step perturbation time: 0.01s
> Perturb sliver vertices (bound: 2) ...
> Build pqueue...done (0 vertices inserted in 0s)
> Step perturbation time: 0s
I can reproduce that behavior on my machine. However, if I add this line as
first line of mesh_two_implicit_spheres_with_balls.cpp:
#define CGAL_MESH_3_USE_RELAXED_HEAP
and recompile the executable, then the exuder works.
We will fix that in future releases of CGAL, to avoid to need for that
workaround macro.
Laurent Rineau, PhD
