cgal-discuss - Fwd: [cgal-discuss] cutting the peanut in half: thin elements
  • To:
  • Subject: Fwd: [cgal-discuss] cutting the peanut in half: thin elements
  • Date: Tue, 21 Jun 2011 19:10:06 -0400
Hi Andreas,
playing around with the debugger and the perturbation, as well as high-verbosity flag, I'm finding that build_prior_queue returns a null pqueue_size in Sliver_perturber.h, and the while loop at line 484 never executes, so nothing gets perturbed...
The output looks like this...
./mesh_two_implicit_spheres_with_balls
Inserting protection balls...
insert_corners() done. Nb of points in triangulation: 0
insert_balls_on_edges() done. Nb of points in triangulation: 13
D vertices.size() 0
refine_balls() done. Nb of points in triangulation: 13
construct initial points:
12/12 initial point(s) found...
Start surface scan...end scan. [Bad facets:35]
Refining Surface...
Legende of the following line: (#vertices,#steps,#facets to refine,#tets to refine)
(121,95,0,0) (791.7 vertices/s))
Total refining surface time: 0.12s
Start volume scan...end scan. [Bad tets:300]
Refining...
(202,92,0,0) (1533.3 vertices/s)))
Total refining volume time: 0.06s
Total refining time: 0.19s
Fill sizing field...done (0.02s)
Running Odt-smoothing...
end interation 13 (82.2 frozen), 36 / 202 (4), last step:0.02s, step avg:0.14s, avg large move:0.061
Convergence reached
Total optimization time: 1.96s
Running sliver perturbation...
Perturb sliver vertices (bound: 1) ...
Build pqueue...done (0 vertices inserted in 0.01s)
Legend of the following line: (#vertices in pqueue, #iterations, #fails)
No perturbation done at this step
Step perturbation time: 0.01s
Perturb sliver vertices (bound: 2) ...
Build pqueue...done (0 vertices inserted in 0s)
Step perturbation time: 0s
(and so on, 0 vertices throughout, you get the picture...)
Perturb sliver vertices (bound: 8) ...
Perturb sliver vertices (bound: 9) ...
Build pqueue...done (4 vertices inserted in 0s)
(0,1,0) (inf iteration/s)
Sq radius gradient perturbation: 100% (1 in 0s)
Volume gradient perturbation: 0% (0 in 0s)
Dihedral angle gradient perturbation: 0% (0 in 0s)
Li random perturbation [100, 0.15, in]: 0% (0 in 0s)
Perturb sliver vertices (bound: 10) ...
Build pqueue...done (4 vertices inserted in 0.01s)
(0,2,0) (200.0 iteration/s)
Sq radius gradient perturbation: 100% (1 in 0.01s)
Step perturbation time: 0.02s
Total perturbation time: 0.06s
Perturbation statistics:
Sq radius gradient perturbation: 100% (2 in 0.01s)
Exuding...
Legend of the following line: (#cells left,#vertices pumped,#vertices ignored)
(0,2,1) (inf vertices/s)
Total exuding time: 0s
Once again, this is the modification to the mesh_two_implicit_spheres... code:
 Mesh_criteria criteria(edge_size = 0.5,
                        facet_angle = 25, facet_size = 0.5,
                        cell_radius_edge_ratio = 2, cell_size = 0.5);
 // Create edge that we want to preserve
 Polylines polylines (1);
 Polyline& polyline = polylines.front();
 // Mesh generation with feature preservation
 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, //);
                                     odt(time_limit=30),
                                     perturb(sliver_bound=10, time_limit=30),
                                     exude(time_limit=30, sliver_bound=15));
#ifndef VTKOUTPUT
  std::ofstream medit_file("out-with-protection.mesh");
  //medit_file.open("out-with-protection.mesh");
  c3t3.output_to_medit(medit_file);
  medit_file.close();
#else
  vtkSmartPointer<vtkUnstructuredGrid>
    outputUnstructuredGrid = vtkSmartPointer<vtkUnstructuredGrid>::New();
  CGAL::output_c3t3_to_vtk_unstructured_grid(c3t3, outputUnstructuredGrid);
  outputUnstructuredGrid->Squeeze();
  vtkSmartPointer<vtkUnstructuredGridWriter> writer =
    vtkSmartPointer<vtkUnstructuredGridWriter>::New();
  writer->SetInput(outputUnstructuredGrid);
  writer->SetFileName("out.vtk");
  writer->Write();
#endif
I'm also playing around with Stellar 1.0 (based on a meshconvert from .mesh to .node, when outputting in non-VTK mode), in the hopes of using it to improve the mesh, and I'm getting an odd summary of the input mesh... There do not appear to be any slivers in these results, according to Stellar. See below...
I don't know what to make of it, except that what I'm seeing in Paraview either
  • indicates that the .vtk file does not reflect the results of the .mesh file, or
  • Paraview and the vtk file are right on, but some of these tets overlap
Thoughts? Best wishes,
Michel
PS:
Stellar 1.0 summary of input
Mesh quality before improvement:
Mesh quality statistics (PHYSICAL SPACE)
  Smallest volume:      0.0090213   |  Largest volume:       0.050776
  Shortest edge:          0.36031   |  Longest edge:           1.0143
  Shortest altitude:      0.15979   |  Largest aspect ratio:   5.1695
  Tetrahedron aspect ratio histogram:
  1.2247 - 1.5       :         25   |     15 - 25         :         0
     1.5 - 2         :        394   |     25 - 50         :         0
       2 - 2.5       :        261   |     50 - 100        :         0
     2.5 - 3         :         46   |    100 - 300        :         0
       3 - 4         :         17   |    300 - 1000       :         0
       4 - 6         :          4   |   1000 - 10000      :         0
       6 - 10        :          0   |  10000 - 100000     :         0
      10 - 15        :          0   | 100000 -            :         0
  (Aspect ratio is longest edge divided by shortest altitude)
  Largest circumradius-to-shortest-edge ratio:                 1.1286
  Tetrahedron circumradius-to-shortest-edge ratio histogram:
  0.6123 - 0.75      :        190   |     15 - 25         :         0
    0.75 - 1         :        520   |     25 - 50         :         0
       1 - 1.5       :         37   |     50 - 100        :         0
     1.5 - 2         :          0   |    100 - 300        :         0
       2 - 3         :          0   |    300 - 1000       :         0
       3 - 5         :          0   |   1000 - 10000      :         0
       5 - 10        :          0   |  10000 - 100000     :         0
  Smallest dihedral:       16.404   |  Largest dihedral:       156.44
  Dihedral angle histogram:
       0 - 10 degrees:          0   |     90 - 100 degrees:       316
      10 - 20 degrees:          8   |    100 - 110 degrees:       268
      20 - 30 degrees:         45   |    110 - 120 degrees:       142
      30 - 40 degrees:        242   |    120 - 130 degrees:        54
      40 - 50 degrees:        588   |    130 - 140 degrees:        33
      50 - 60 degrees:        861   |    140 - 150 degrees:        10
      60 - 70 degrees:        775   |    150 - 160 degrees:         3
      70 - 80 degrees:        615   |    160 - 170 degrees:         0
      80 - 90 degrees:        522   |    170 - 180 degrees:         0
  For a histogram, input the following line to hist.c:
  0 0 0 0 0 0 0 0 3 5 6 5 7 10 17 30 36 52 57 67 81 103 118 135 151 146 170 167 196 182 189 165 138 155 128 135 135 123 111 111 115 119 106 91 91 74 69 62 56 55 56 47 54 60 51 48 25 26 23 20 13 11 11 9 10 7 11 4 8 3 3 3 1 3 0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0     16.40352     156.4417
  For a rnrrratio histogram, input the following line to hist.c:
  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 1 0 0 1 0 0 1 2 0 0 0 0 1 2 0 0 1 1 3 3 2 1 2 1 2 3 4 4 3 5 2 3 4 6 11 8 10 10 15 16 15 9 17 19 24 25 24 28 28 33 33 35 29 27 31 39 35 28 29 37 20 23 14 11 5 0    0.2966215    0.9854242
  For a vlrms3ratio histogram, input the following line to hist.c:
  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 3 0 1 0 1 0 0 1 1 1 0 2 1 1 2 2 2 1 1 3 3 0 6 4 3 3 7 6 9 3 4 8 12 9 13 17 11 16 7 18 13 16 19 28 18 16 22 29 24 32 36 18 24 27 26 23 25 30 28 23 23 24 11 9 13 6 1 0    0.2724383     0.981271
worstqual:    0.2824005
The worst input angle is 2.67587 radians (153.316 degrees).
Performing vertex classification.
Computing intial surface quadrics
Quadriccheck:
    Average quadric error: -2.62828e-16
    Number non-zero:       98
    Minimum quadric error: -1.42109e-14
    Maximum quadric error: 1.06581e-14
    Average gradient mag:  1.38175e-15
    Minimum gradient mag:  0
    Maximum gradient mag:  1.07043e-14
    Average dot mag:       1.07678
    Minimum dot mag:       0.522799
    Maximum dot mag:       1.69926
Edge length statistics:
    Longest edge:          1.01426
    Longest desired edge:  0.75
    Shortest edge:         0.360311
    Shortest desired edge: 0.4
    Mean edge:             0.664016
    Median edge:           0.661525
    Ideal edge:            0.5
The VTK output is visualized with slice through the volume in
On Mon, Jun 20, 2011 at 4:57 PM, Michel Audette <> wrote:
> Hi Andreas,
> it does not look very different with . The post-processing is being
> triggered, but looks like it might not be well tuned. I'm including the
> readout in verbose mode below...
> I'm open to tuning it further, if there is something that I'm not doing
> right. If I didn't know better, some of these look like thin hexes, or at
> least the slice-intersection looks like thin quads, for some shapes, but
> every cell is indeed 4 points, from what I can tell. I'm going to poke
> around with high verbosity.
> Cheers,
> Michel
> michel@michel-desktop:~/simProject/NeuroSurgSim/SimplexDecimationBuild/bin$
> !./me
>  D vertices.size() 0
> Start surface scan...end scan. [Bad facets:32]
> Refining Surface...
> refine)
> (129,106,0,0) (706.7 vertices/s)
> Total refining surface time: 0.15s
> Start volume scan...end scan. [Bad tets:299]
> Refining...
> refine)
> (207,87,0,0) (1450.0 vertices/s)))
> Total refining time: 0.22s
> Fill sizing field...done (0.03s)
> end interation 12 (77.8 frozen), 46 / 207 (5), last step:0.03s, step
> avg:0.16s, avg large move:0.078
> Convergence reached
> Total optimization time: 2.1s
> bound 9: (0,1,0) (25.0 iteration/s)
> Total perturbation time: 0.05s
> Exuding...
> ignored)
> (0,5,10) (500.0 vertices/s)
> Total exuding time: 0.02s
> On Mon, Jun 20, 2011 at 3:42 PM, Michel Audette <>
> wrote:
>> Hi Andreas,
>> thanks for your prompt reply, and I apologize if the email just sent is
>> also covered by this workaround.
>> I'll give it a try and report back.
>> Best wishes,
>> Michel
>> On Mon, Jun 20, 2011 at 3:35 PM, Andreas Fabri
>> <> wrote:
>>> Hi Michel,
>>> Some days ago we found a bug in the code that removes slivers.
>>> The workaround is to define the macro
>>> CGAL_MESH_3_USE_RELAXED_HEAP
>>> Can you report back if it helped in your case.
>>> andreas
>>> On 20/06/2011 20:58, Michel Audette wrote:
>>>> Dear CGAL developers,
>>>> In the past week or so, I've become interested in the new capacity of
>>>> 3.8 to offer boundary-faithful and controlled-resolution
>>>> tetrahedralization.
>>>> Returning to the example in
>>>> examples/Mesh_3/mesh_two_implicit_spheres_with_balls.cpp,
>>>> playing with the mesh size a little bit,
>>>>                                       odt(time_limit=30),
>>>> time_limit=30),
>>>> sliver_bound=15));
>>>> and visualizing the interior with Paraview (by producing a vtk file),
>>>>   writer->Write();
>>>> I'm finding nonetheless that some slivers remain in the peanut... See
>>>> the enclosed visualization. I'd be happy to help track down the problem.
>>>> Is this a parameter of odt(), perturb() or exude() that I am not using
>>>> properly?
>>>> Best wishes,
>>>> Michel
>>>> Michel Audette, Ph.D.
>>>> R & D Engineer,
>>>> Kitware Inc.,
>>>> Chapel Hill, N.C.
>>> Andreas Fabri, PhD
>>> Chief Officer, GeometryFactory
>>> Editor, The CGAL Project
>>> phone: +33.492.954.912    skype: andreas.fabri
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
>> R & D Engineer,
>> Kitware Inc.,
>> Chapel Hill, N.C.
> R & D Engineer,
> Kitware Inc.,
> Chapel Hill, N.C.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
Attachment: out.vtk
Description: Binary data
Attachment: out-with-protection.mesh
Description: Mesh model
Attachment: outputStellar
