cgal-discuss - Re: [cgal-discuss] cutting the peanut in half: thin elements
  • To:
  • Subject: Re: [cgal-discuss] cutting the peanut in half: thin elements
  • Date: Mon, 20 Jun 2011 15:42:22 -0400
Hi Andreas,
thanks for your prompt reply, and I apologize if the email just sent is also covered by this workaround.
I'll give it a try and report back.
Best wishes,
Michel
On Mon, Jun 20, 2011 at 3:35 PM, Andreas Fabri <> wrote:
Hi Michel,
Some days ago we found a bug in the code that removes slivers.
The workaround is to define the macro
CGAL_MESH_3_USE_RELAXED_HEAP
Can you report back if it helped in your case.
andreas
On 20/06/2011 20:58, Michel Audette wrote:
Dear CGAL developers,
In the past week or so, I've become interested in the new capacity of
3.8 to offer boundary-faithful and controlled-resolution tetrahedralization.
Returning to the example in
examples/Mesh_3/mesh_two_implicit_spheres_with_balls.cpp,
playing with the mesh size a little bit,
 Mesh_criteria criteria(edge_size = 0.5,
                        facet_angle = 25, facet_size = 0.5,
                        cell_radius_edge_ratio = 2, cell_size = 0.5);
  c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria,
                                      odt(time_limit=30),
                                      perturb(sliver_bound=10,
time_limit=30),
                                      exude(time_limit=30,
sliver_bound=15));
and visualizing the interior with Paraview (by producing a vtk file),
  vtkSmartPointer<vtkUnstructuredGrid>
    outputUnstructuredGrid = vtkSmartPointer<vtkUnstructuredGrid>::New();
  CGAL::output_c3t3_to_vtk_unstructured_grid(c3t3, outputUnstructuredGrid);
  outputUnstructuredGrid->Squeeze();
  vtkSmartPointer<vtkUnstructuredGridWriter> writer =
    vtkSmartPointer<vtkUnstructuredGridWriter>::New();
  writer->SetInput(outputUnstructuredGrid);
  writer->SetFileName("out.vtk");
  writer->Write();
I'm finding nonetheless that some slivers remain in the peanut... See
the enclosed visualization. I'd be happy to help track down the problem.
Is this a parameter of odt(), perturb() or exude() that I am not using
properly?
Best wishes,
Michel
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912    skype: andreas.fabri
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
