- To:
- Subject: Re: [cgal-discuss] Re: how to run demo after build VS2008
- Date: Fri, 24 Jun 2011 10:49:08 +0200
On jeudi 23 juin 2011 19:05:01 tang wrote:
> Dear Dr. Rineau,
> I am a beginner of CGAL. I am trying to configure the CGAL according to the
> instructions
> http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_inst
> allation_manual.html#Section_4 and
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on
> -windows
> however, there are still some errors as shown below, could you please help
> me to check these problems?
In you cmake log, I swa two things:
1/ A lot of warnings about CMP0017 (that was introduced in CMake after
CGAL-3.8 has been released). Just use the -Wno-dev flag if you want, or
ignore those warning.
2/ A non-fatal error about ZLIB, that was found in "C:/Program Files
(x86)/GnuWin32/" but does not seem compatible with Microsoft Visual.
The ZLIB issue may cause an error during the compilation of the ImageIO
library of CGAL, but I think you can just use WITH_CGAL_ImageIO=FALSE. It
would be better to install another zlib version compatible with Microsoft
Visual.
I have not seen any error that can prevent you from building CGAL libraries
(but CGAL_ImageIO), and most examples and demos.
Laurent Rineau, PhD
- [cgal-discuss] Re: how to run demo after build VS2008, tang, 06/23/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Laurent Rineau (GeometryFactory), 06/24/2011
- RE: [cgal-discuss] Re: how to run demo after build VS2008, Zhanghong Tang, 06/24/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Sebastien Loriot (GeometryFactory), 06/24/2011
- RE: [cgal-discuss] Re: how to run demo after build VS2008, Zhanghong Tang, 06/25/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Laurent Rineau (GeometryFactory), 06/27/2011
