- To: <>
- Subject: RE: [cgal-discuss] Re: how to run demo after build VS2008
- Date: Fri, 24 Jun 2011 21:48:08 +1200
- Importance: Normal
Dear Dr. Rineau,
Thank you very much for your kindly reply. Now the ZLIB problem is solved. The main problem is as follows: NOTICE: This demo requires QGLViewer, and will not be compiled. However, I have put the QGLViewer into a folder but I don't know how to specify this path. Thanks, Zhanghong Tang > From: > To: > Date: Fri, 24 Jun 2011 10:49:08 +0200 > Subject: Re: [cgal-discuss] Re: how to run demo after build VS2008 > > On jeudi 23 juin 2011 19:05:01 tang wrote: > > Dear Dr. Rineau, > > > > I am a beginner of CGAL. I am trying to configure the CGAL according to the > > instructions > > http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_inst > > allation_manual.html#Section_4 and > > http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on > > -windows > > > > however, there are still some errors as shown below, could you please help > > me to check these problems? > > In you cmake log, I swa two things: > 1/ A lot of warnings about CMP0017 (that was introduced in CMake after > CGAL-3.8 has been released). Just use the -Wno-dev flag if you want, or > ignore those warning. > 2/ A non-fatal error about ZLIB, that was found in "C:/Program Files > (x86)/GnuWin32/" but does not seem compatible with Microsoft Visual. > > The ZLIB issue may cause an error during the compilation of the ImageIO > library of CGAL, but I think you can just use WITH_CGAL_ImageIO=FALSE. It > would be better to install another zlib version compatible with Microsoft > Visual. > > I have not seen any error that can prevent you from building CGAL libraries > (but CGAL_ImageIO), and most examples and demos. > > -- > Laurent Rineau, PhD > R&D Engineer at GeometryFactory http://www.geometryfactory.com/ > Release Manager of the CGAL Project http://www.cgal.org/ > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss > |
- [cgal-discuss] Re: how to run demo after build VS2008, tang, 06/23/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Laurent Rineau (GeometryFactory), 06/24/2011
- RE: [cgal-discuss] Re: how to run demo after build VS2008, Zhanghong Tang, 06/24/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Sebastien Loriot (GeometryFactory), 06/24/2011
- RE: [cgal-discuss] Re: how to run demo after build VS2008, Zhanghong Tang, 06/25/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Laurent Rineau (GeometryFactory), 06/27/2011
