cgal-discuss - Re: [cgal-discuss] Re: how to run demo after build VS2008
  • To:
  • Subject: Re: [cgal-discuss] Re: how to run demo after build VS2008
  • Date: Fri, 24 Jun 2011 12:01:04 +0200
Zhanghong Tang wrote:
> Dear Dr. Rineau,
> Thank you very much for your kindly reply. Now the ZLIB problem is
> solved. The main problem is as follows:
> NOTICE: This demo requires QGLViewer, and will not be compiled.
> However, I have put the QGLViewer into a folder but I don't know how to
> specify this path.
Have a look here:
http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_10.4
And look for QGLviewer subsection.
Sebastien.
> Thanks,
> Zhanghong Tang
> > From:
> > To:
> > Date: Fri, 24 Jun 2011 10:49:08 +0200
> > On jeudi 23 juin 2011 19:05:01 tang wrote:
> > > Dear Dr. Rineau,
> > > I am a beginner of CGAL. I am trying to configure the CGAL
> according to the
> > > instructions
> > > allation_manual.html#Section_4 and
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on
> > > -windows
> > > however, there are still some errors as shown below, could you
> please help
> > > me to check these problems?
> > In you cmake log, I swa two things:
> > 1/ A lot of warnings about CMP0017 (that was introduced in CMake after
> > CGAL-3.8 has been re leased). Just use the -Wno-dev flag if you want, or
> > ignore those warning.
> > 2/ A non-fatal error about ZLIB, that was found in "C:/Program Files
> > (x86)/GnuWin32/" but does not seem compatible with Microsoft Visual.
> > The ZLIB issue may cause an error during the compilation of the ImageIO
> > library of CGAL, but I think you can just use
> WITH_CGAL_ImageIO=FALSE. It
> > would be better to install another zlib version compatible with
> Microsoft
> > Visual.
> > I have not seen any error that can prevent you from building CGAL
> libraries
> > (but CGAL_ImageIO), and most examples and demos.
> > Laurent Rineau, PhD
> > R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> > Release Manager of the CGAL Project http://www.cgal.org/
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives , go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
