- To: <>
- Subject: RE: [cgal-discuss] Re: how to run demo after build VS2008
- Date: Sat, 25 Jun 2011 12:13:54 +1200
- Importance: Normal
Dear Dr. Rineau,
Thank you very much for your kindly reply. I downloaded latest "libQGLViewer-2.3.10" and build it, the libraries "QGLViewer2.lib" and "QGLViewer2.dll" are generated. After reconfigured the CGAL by CMAKE, I build the CGAL projects by VS2010, still 24 projects failed. Most of the errors are as follows: unresolved external symbol "__declspec(dllimport) public: void __thiscall qglviewer::Frame::setPosition(float,float,float)" (__imp_?setPosition@Frame@qglviewer@@QAEXMMM@Z) referenced in function "public: void __thiscall Polyhedron_demo_pca_plugin::on_actionFitPlane_triggered(void)" (?on_actionFitPlane_triggered@Polyhedron_demo_pca_plugin@@QAEXXZ) Could you please help me to take a look at it? Thanks, Zhanghong Tang > Date: Fri, 24 Jun 2011 12:01:04 +0200 > From: > To: > Subject: Re: [cgal-discuss] Re: how to run demo after build VS2008 > > Zhanghong Tang wrote: > > Dear Dr. Rineau, > > > > Thank you very much for your kindly reply. Now the ZLIB problem is > > solved. The main problem is as follows: > > > > NOTICE: This demo requires QGLViewer, and will not be compiled. > > > > > > However, I have put the QGLViewer into a folder but I don't know how to > > specify this path. > Have a look here: > http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_10.4 > And look for QGLviewer subsection. > > Sebastien. > > > > > > > > > Thanks, > > Zhanghong Tang > > > > > > > From: > > > To: > > > Date: Fri, 24 Jun 2011 10:49:08 +0200 > > > Subject: Re: [cgal-discuss] Re: how to run demo after build VS2008 > > > > > > On jeudi 23 juin 2011 19:05:01 tang wrote: > > > > Dear Dr. Rineau, > > > > > > > > I am a beginner of CGAL. I am trying to configure the CGAL > > according to the > > > > instructions > > > > > > http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_inst > > > > allation_manual.html#Section_4 and > > > > > > http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on > > > > -windows > > > > > > > > however, there are still some errors as shown below, could you > > please help > > > > me to check these problems? > > > > > > In you cmake log, I swa two things: > > > 1/ A lot of warnings about CMP0017 (that was introduced in CMake after > > > CGAL-3.8 has been re leased). Just use the -Wno-dev flag if you want, or > > > ignore those warning. > > > 2/ A non-fatal error about ZLIB, that was found in "C:/Program Files > > > (x86)/GnuWin32/" but does not seem compatible with Microsoft Visual. > > > > > > The ZLIB issue may cause an error during the compilation of the ImageIO > > > library of CGAL, but I think you can just use > > WITH_CGAL_ImageIO=FALSE. It > > > would be better to install another zlib version compatible with > > Microsoft > > > Visual. > > > > > > I have not seen any error that can prevent you from building CGAL > > libraries > > > (but CGAL_ImageIO), and most examples and demos. > > > > > > -- > > > Laurent Rineau, PhD > > > R&D Engineer at GeometryFactory http://www.geometryfactory.com/ > > > Release Manager of the CGAL Project http://www.cgal.org/ > > > > > > -- > > > You are currently subscribed to cgal-discuss. > > > To unsubscribe or access the archives , go to > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss > |
- [cgal-discuss] Re: how to run demo after build VS2008, tang, 06/23/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Laurent Rineau (GeometryFactory), 06/24/2011
- RE: [cgal-discuss] Re: how to run demo after build VS2008, Zhanghong Tang, 06/24/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Sebastien Loriot (GeometryFactory), 06/24/2011
- RE: [cgal-discuss] Re: how to run demo after build VS2008, Zhanghong Tang, 06/25/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Sebastien Loriot (GeometryFactory), 06/27/2011
- Re: [cgal-discuss] Re: how to run demo after build VS2008, Laurent Rineau (GeometryFactory), 06/27/2011
