cgal-discuss - [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction
  • To:
  • Subject: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction
  • Date: Mon, 1 Aug 2011 23:58:46 -0700 (PDT)
Yes I'm still stuck with Poisson Surface Reconstruction.
The problems:
1) How can I activate CGAL Trace ?
2) Why have I problems with surface reconstruction when the point set
contains more then 250 000 points.
What I made so far:
- I took the 752_bimba_1Mfaces_noautointersect.off file on the website and I
put the point set in a .xyz file.
- I run the Point_set_processing_3/normals_example.cpp to generate the
normal’s and saved it again in a .xyz file. Result: 500 000 points.
- Finally I run the
surface_reconstruction_points_3/poisson_reconstruction_example.cpp in which
I just added a point set simplification.
Results:
- It works well with less than 200 000 point, above I have the message error
(Error: cannot solve Poisson equation)
- When I use my point set (average spacing: 25) it works also with less than
200 000 points and above I have directly a crash in taucs. Why did I have
such a gap between my application (200k points) and yours (1.3M points)?
Thanks,
Marc
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Poisson-Surface-Reconstruction-tp3616368p3711492.html
