cgal-discuss - Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04
  • To:
  • Subject: Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04
  • Date: Mon, 22 Aug 2011 17:50:05 +0200
On lundi 22 août 2011 14:11:36 mm wrote:
> Amy Tabb wrote:
> > My opinion of how to fix your problem is to keep the newest version of
> > boost (at least 1.44), and then skip the Synaptic package manager version
> > of cgal and instead build it from source. In the cmake dialog, you can
> > manually point to the specific version of boost that you have, but when I
> > have installed it on Ubuntu there was no need to alter the libraries
> > found by cmake.
> > Then you'll have the most up to date version of boost with the most up to
> > date version of cgal, the only negative being some long download and
> > build times.
> Joachim Reichel wrote:
> > If you don't want to/can't do that yourself there seem to be two options:
> > 1) Build CGAL yourself from source, as recommended by Amy.
> > 2) Use a newer CGAL package from Ubuntu oneiric or Debian squeeze (CGAL
> > 3.8 / Boost 1.46).
> Hey Amy and Joachim, thanks for answering that fast! My response comes a
> bit late, but I was afk all weekend long.
> What both of you said makes total sense and I'd like to follow Amy's
> recommendation and compile CGAL from source and link against that.
> Unfortunately, it's not working. Setup is like this:
> 1) downloaded
> https://gforge.inria.fr/frs/download.php/28501/CGAL-3.8.tar.xz 2) unpacked
> and called cmake: only option changed is:
> CMAKE_INSTALL_PREFIX = /home/mm/.local/CGAL-3.8/
> as that's the place I keep my selfcompiled software.
> 3) open my project in cmake and set
> CGAL_DIR = /home/mm/.local/CGAL-3.8/lib/CGAL
> It's the only CGAL option and originally when I install CGAL through
> Synaptic, the folder /usr/lib/CGAL contains the same files, mostly *.cmake
> or *.in files.
I imagine that you did not erased your CMakeCache.txt file (at the root of
the
build-tree of your project) before re-running CMake. Please check what is the
value of CGAL_DIR in that file. Probably the CGAL installation in /usr is
still found.
Note that CMake-GUI is a nice tool to modify CMake cache values.
Laurent Rineau, PhD
