- To:
- Subject: Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04
- Date: Mon, 22 Aug 2011 19:05:14 +0200
Hi mm,
> Yes, I also dislike the idea of setting environment variables for such a
> thing and I also know the -I switch. But as I stated: the compiler line is
> exactly the same, where once it works - for the Ubuntu CGAL version in
> /usr/lib/CGAL - while the other time, it does not - for the self-compiled
> version in /home/mm/.local/CGAL-3.8/lib/CGAL
> So, I guess it's not the problem of that compiler switch...
1) You should uninstall the precompiled CGAL packages to avoid using
them accidentally.
2) You need explicit -I, -L, and probably -Wl,-R directives. They are
not needed with the precompiled packages because those use prefix /usr
which is searched by default.
Joachim
- Re: [cgal-discuss] libboost dependencies in Ubuntu 11.04, (continued)
- Re: [cgal-discuss] libboost dependencies in Ubuntu 11.04, Joachim Reichel, 08/19/2011
- [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, mm, 08/22/2011
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, Philipp Möller, 08/22/2011
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, Laurent Rineau (GeometryFactory), 08/22/2011
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, Joachim Reichel, 08/22/2011
- [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, mm, 08/25/2011
