- To:
- Subject: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04
- Date: Mon, 22 Aug 2011 09:25:00 -0700 (PDT)
Laurent Rineau (GeometryFactory) wrote:
> On lundi 22 août 2011 14:11:36 mm wrote:
> I imagine that you did not erased your CMakeCache.txt file (at the root of
> the
> build-tree of your project) before re-running CMake. Please check what is
> the
> value of CGAL_DIR in that file. Probably the CGAL installation in /usr is
> still found.
> Note that CMake-GUI is a nice tool to modify CMake cache values.
I am using CMake-GUI and I just double checked: the value of CGAL_DIR in
CMakeCache.txt is set correctly to /home/mm/.local/CGAL-3.8/lib/CGAL after
running configure & generate in CMake-GUI. :-/
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/libboost-dependencies-in-Ubuntu-11-04-tp3755646p3760581.html
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, (continued)
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, Philipp Möller, 08/22/2011
- [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, mm, 08/22/2011
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, Laurent Rineau (GeometryFactory), 08/22/2011
- Re: [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, Joachim Reichel, 08/22/2011
- [cgal-discuss] Re: libboost dependencies in Ubuntu 11.04, mm, 08/25/2011
