- To:
- Subject: Re: [cgal-discuss] 3D Mesh - not all sharp features preserved.
- Date: Wed, 5 Oct 2011 19:08:31 +0200
On mercredi 05 octobre 2011 10:21:46 Maarten Moesen wrote:
> Dear all,
> I'm currently trying out the sharp-feature preservation of CGAL's 3D mesh
> generator on a 32-bit machine with MSVC 2008 (version 3.8, with Laurent
> Rineau's Triangulation_data_structure_3.h patch applied). My test geometry
> is a box having a big sphere cut out from its center. I add as 1D sharp
> features using line segments the circles where the sphere cuts the sides
> of the box, as well as the ribs of the box. Unfortunately, the mesher does
> not preserve all the features near the circle... most of the times a few
> segments are missing. The sample code is below. An example mesh is also
> attached.
Hi Maarten,
Thanks for your complete report. I was able to reproduce your experiment
easily.
Actually the sharp features are preserved: "missing" segments are actually in
the 3D complex. What is missing is the two incident facets!
Your domain is defined as an implicit surface (iso-surface of a function).
Because of that, even if the surface of the domain can be decomposed into
patches (separated by sharp curves), the "surface_patch_index" is the same
for
all triangles of the mesh. If your domain was able to tag surface patches
differently, with different surface indices, then the topological criterion
CGAL::parameters::facet_topology=CGAL::FACET_VERTICES_ON_SAME_SURFACE_PATCH
could "fix" the issues you have around sharp curves that correspond to a
small
angle (say, less than 30°).
Another way of fixing that is by decreasing the ratio edge_size/facet_size,
or
decreasing the facet_distance.
Laurent Rineau, PhD
- [cgal-discuss] 3D Mesh - not all sharp features preserved., Maarten Moesen, 10/05/2011
- Re: [cgal-discuss] 3D Mesh - not all sharp features preserved., Laurent Rineau (GeometryFactory), 10/05/2011
- Re: [cgal-discuss] 3D Mesh - not all sharp features preserved., Maarten Moesen, 10/06/2011
