cgal-discuss - [cgal-discuss] 3D Mesh - not all sharp features preserved.
  • To:
  • Subject: [cgal-discuss] 3D Mesh - not all sharp features preserved.
  • Date: Wed, 5 Oct 2011 10:21:46 +0200
Dear all,
I'm currently trying out the sharp-feature preservation of CGAL's 3D mesh generator on a 32-bit machine with MSVC 2008 (version 3.8, with Laurent Rineau's Triangulation_data_structure_3.h patch applied). My test geometry is a box having a big sphere cut out from its center. I add  as 1D sharp features  using line segments the circles where the sphere cuts the sides of the box, as well as the ribs of the box. Unfortunately, the mesher does not preserve all the features near the circle... most of the times a few segments are missing. The sample code is below. An example mesh is also attached.
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Mesh_domain_with_polyline_features_3.h>
#include <CGAL/Implicit_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/Timer.h>
namespace POMO
const double PI = 3.14159265358979323846264338327950288419716939937510582097494459230781640628620899862803482534211706798;
// Domain
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::FT FT;
typedef K::Point_3 Point;
class Cubic_function : public std::unary_function<Point,FT>
public:
  Cubic_function(double const& radius = 0.6): m_x0(0), m_y0(0), m_z0(0), m_x1(1), m_y1(1), m_z1(1), m_xc(0.5), m_yc(0.5), m_zc(0.5), m_r(radius) {}
  FT const& x_min() const { return m_x0; }
  FT const& x_max() const { return m_x1; }
  FT const& y_min() const { return m_y0; }
  FT const& y_max() const { return m_y1; }
  FT const& z_min() const { return m_z0; }
  FT const& z_max() const { return m_z1; }
  FT const& x_cen() const { return m_xc; }
  FT const& y_cen() const { return m_yc; }
  FT const& z_cen() const { return m_zc; }
  FT const& radius() const { return m_r; }
  FT square(FT const& x) const
    return x*x;
  FT operator()(const Point& p) const
    return std::max(std::max(std::max(std::max(x_min()-p.x(), p.x()-x_max()), std::max(y_min()-p.y(), p.y()-y_max())), std::max(z_min()-p.z(), p.z()-z_max())),
                    square(radius()) - square(x_cen()-p.x()) - square(y_cen()-p.y()) - square(z_cen()-p.z()) );
  K::Sphere_3 bounding_sphere() const
    return K::Sphere_3(Point(0.04, 0.04, 0.04), 3.0);
private:
  FT m_x0, m_x1, m_y0, m_y1, m_z0, m_z1, m_xc, m_yc, m_zc, m_r;
//typedef FT (Function)(const Point&);
typedef CGAL::Implicit_mesh_domain_3<Cubic_function,K> Implicit_mesh_domain;
typedef CGAL::Mesh_domain_with_polyline_features_3<Implicit_mesh_domain> Mesh_domain;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr,Mesh_domain::Corner_index,Mesh_domain::Curve_segment_index> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
typedef std::vector<Point>        Polyline;
typedef std::vector<Polyline>     Polylines;
int main()
  CGAL::Timer timer;
  Cubic_function fun;
  Mesh_domain domain(fun, fun.bounding_sphere(), 1e-6);
  double edge_length = 0.05;
  // Mesh criteria
  Mesh_criteria criteria(CGAL::parameters::facet_angle=30,
    CGAL::parameters::edge_size=edge_length,
    CGAL::parameters::facet_size=edge_length*2,
    CGAL::parameters::facet_distance=0.001,
    CGAL::parameters::cell_radius_edge_ratio=2,
    CGAL::parameters::cell_size=edge_length*2);
  // The ribs of the cube
  Point p000(fun.x_min(), fun.y_min(), fun.z_min());
  Point p001(fun.x_min(), fun.y_min(), fun.z_max());
  Point p010(fun.x_min(), fun.y_max(), fun.z_min());
  Point p011(fun.x_min(), fun.y_max(), fun.z_max());
  Point p100(fun.x_max(), fun.y_min(), fun.z_min());
  Point p101(fun.x_max(), fun.y_min(), fun.z_max());
  Point p110(fun.x_max(), fun.y_max(), fun.z_min());
  Point p111(fun.x_max(), fun.y_max(), fun.z_max());
  Polylines polylines(18);
  polylines[0].push_back(p000); polylines[0].push_back(p100);
  polylines[1].push_back(p001); polylines[1].push_back(p101);
  polylines[2].push_back(p010); polylines[2].push_back(p110);
  polylines[3].push_back(p011); polylines[3].push_back(p111);
  polylines[4].push_back(p000); polylines[4].push_back(p010);
  polylines[5].push_back(p001); polylines[5].push_back(p011);
  polylines[6].push_back(p100); polylines[6].push_back(p110);
  polylines[7].push_back(p101); polylines[7].push_back(p111);
  polylines[8].push_back(p000); polylines[8].push_back(p001);
  polylines[9].push_back(p010); polylines[9].push_back(p011);
  polylines[10].push_back(p100); polylines[10].push_back(p101);
  polylines[11].push_back(p110); polylines[11].push_back(p111);
  double rad = CGAL::to_double(fun.radius());
  rad = std::sqrt(rad*rad - 0.25);
  int n = std::max(8, static_cast<int>(std::ceil(2*POMO::PI*rad/edge_length)));
  double* cs = new double[n+1];
  double* ss = new double[n+1];
  for (int ci = 0; ci < n; ++ci)
    double angle = 2*POMO::PI*ci/n;
    cs[ci] = 0.5 + rad*std::cos(angle);
    ss[ci] = 0.5 + rad*std::sin(angle);
  cs[n] = cs[0];
  ss[n] = ss[0];
  std::cout << "Radius: " << rad << "\nNumber of points: " << n << std::endl;
  for (int ci = 0; ci <= n; ++ci)
    //std::cout << fun(Point(0.0, cs[ci], ss[ci])) << "   " << fun(Point(1.0, cs[ci], ss[ci])) << std::endl;
    polylines[12].push_back(Point(0.0, cs[ci], ss[ci]));
    polylines[13].push_back(Point(1.0, cs[ci], ss[ci]));
    polylines[14].push_back(Point(cs[ci], 0.0, ss[ci]));
    polylines[15].push_back(Point(cs[ci], 1.0, ss[ci]));
    polylines[16].push_back(Point(cs[ci], ss[ci], 0.0));
    polylines[17].push_back(Point(cs[ci], ss[ci], 1.0));
  delete [] cs;
  delete [] ss;
  domain.add_features(polylines.begin(), polylines.end());
  // Mesh generation
  std::cout << "Generating the mesh: ";
  timer.reset();timer.start();
  C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, CGAL::parameters::no_exude(), CGAL::parameters::no_perturb());
  timer.stop();
  std::cout << timer.time() << " s." << std::endl;
  std::cout << "ODT Smoothing: ";
  CGAL::Mesh_optimization_return_code code = CGAL::odt_optimize_mesh_3(c3t3, domain);
  timer.stop();
  std::cout << timer.time() << " s. Return code: " << code << std::endl;
  std::cout << "Perturbation: ";
  code = CGAL::perturb_mesh_3(c3t3, domain);
  timer.stop();
  std::cout << "Sliver exudation: ";
  code = CGAL::exude_mesh_3(c3t3);
  timer.stop();
  // Output
  std::ofstream medit_file("sphere_in_box.mesh");
  c3t3.output_to_medit(medit_file);
  medit_file.close();
  std::cout << "Mesh saved to sphere_in_box.mesh" << std::endl;
  std::cout << "Number of cells in complex: " << c3t3.number_of_cells() << std::endl;
  std::cout << "Number of cells in triangulation: " << c3t3.triangulation().number_of_cells() << std::endl;
  std::cout << "Number of finite cells in triangulation: " << c3t3.triangulation().number_of_finite_cells() << std::endl;
  std::cout << "Number of vertices in triangulation: " << c3t3.triangulation().number_of_vertices() << std::endl;
  return 0;
Maarten Moesen, PHD
Polymer Physicist Computational Modeling
HUNTSMAN (Europe) BVBA
Everslaan 45
B-3078 Everberg
Office Phone: 0032 (0) 2 758 9962
