- To:
- Subject: Re: [cgal-discuss] 3D Mesh - not all sharp features preserved.
- Date: Thu, 6 Oct 2011 17:25:05 +0200
Dear Laurent,
Thank you for your answer. I'll study the manual to understand better how to tag regions and surfaces and try it out.
Best regards,
Maarten
Maarten Moesen, PHD
Polymer Physicist Computational Modeling
HUNTSMAN (Europe) BVBA
Everslaan 45
B-3078 Everberg
Office Phone: 0032 (0) 2 758 9962
"Laurent Rineau (GeometryFactory)" <> wrote on 10/05/2011 07:08:31 PM:
> On mercredi 05 octobre 2011 10:21:46 Maarten Moesen wrote:
> > Dear all,
> > I'm currently trying out the sharp-feature preservation of CGAL's 3D mesh
> > generator on a 32-bit machine with MSVC 2008 (version 3.8, with Laurent
> > Rineau's Triangulation_data_structure_3.h patch applied). My test geometry
> > is a box having a big sphere cut out from its center. I add as 1D sharp
> > features using line segments the circles where the sphere cuts the sides
> > of the box, as well as the ribs of the box. Unfortunately, the mesher does
> > not preserve all the features near the circle... most of the times a few
> > segments are missing. The sample code is below. An example mesh is also
> > attached.
> Hi Maarten,
> Thanks for your complete report. I was able to reproduce your experiment
> easily.
> Actually the sharp features are preserved: "missing" segments are actually in
> the 3D complex. What is missing is the two incident facets!
> Your domain is defined as an implicit surface (iso-surface of a function).
> Because of that, even if the surface of the domain can be decomposed into
> patches (separated by sharp curves), the "surface_patch_index" is
> the same for
> all triangles of the mesh. If your domain was able to tag surface patches
> differently, with different surface indices, then the topological criterion
> CGAL::parameters::facet_topology=CGAL::FACET_VERTICES_ON_SAME_SURFACE_PATCH
> could "fix" the issues you have around sharp curves that correspond
> to a small
> angle (say, less than 30°).
> Another way of fixing that is by decreasing the ratio
> edge_size/facet_size, or
> decreasing the facet_distance.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] 3D Mesh - not all sharp features preserved., Maarten Moesen, 10/05/2011
- Re: [cgal-discuss] 3D Mesh - not all sharp features preserved., Laurent Rineau (GeometryFactory), 10/05/2011
- Re: [cgal-discuss] 3D Mesh - not all sharp features preserved., Maarten Moesen, 10/06/2011
