- To:
- Subject: Re: [cgal-discuss] Problems with a 3D Triangulation
- Date: Tue, 25 Oct 2011 13:16:09 +0200
Dear Juan Carlos
I have two questions related with a 3D triangulation using exclusively CGAL:
I have a List of Points (std::list<Point> L;;) with exactly 3278828
points and I have created a Triangulation using this constructor
(Triangulation T(L.begin(), L.end());) with the above mentioned list
of points. My first quation is, Why my triangulation have less points,
exactly 3261840 when I call this function (size_type vertices =
T.number_of_vertices();)?
my guess is that you have identical points in your set
The second is related with the time of
computation, my triangulation delay 3.4 hours in a normal portatil, Is
it normal?
The following section of the manual will give you hints about expected running times (~ 10 seconds for 1 million points)
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_38.6.1
With more than 3 million points, you might encounter problems with memory and swap, depending on your computer.
Best regards,
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] Problems with a 3D Triangulation, Juan Carlos Lopez Alfonso, 10/25/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Monique Teillaud, 10/25/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Juan Carlos Lopez Alfonso, 10/25/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Marc Glisse, 10/25/2011
- Re: [cgal-discuss] Problems with a 3D Triangulation, Andreas Fabri, 10/25/2011
