- To:
- Subject: Re: [cgal-discuss] 3D mesh of a domain with several holes
- Date: Fri, 28 Oct 2011 19:29:54 +0200
On 28/10/2011 19:11, Adam Hopkins wrote:
Hello:
I dont know if is possible build 3D triangulations of nonconvex domains,
for example with several holes inside the domain. Assume that I have a
set of points (x,y,z) (for example defining a human head) where I want
to consider several irregular holes inside and where these holes are
totally included in this set of points (for example I am considering my
holes like tumours). I want to define my triangulation from my set of
points and I can know the boundary points of these holes. Is possible
triangulate this domain with cgal , where I can exclude the 3D
triangulation of these interior holes?
Thak you and best regards
Adam.
Not sure to understand.
Do your points describe the surface of the head,
or the volume?
You might have a look at Alpha shapes, and in the first
case at poisson surface reconstruction.
andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] 3D mesh of a domain with several holes, adam.hopkins83, 10/28/2011
- <Possible follow-up(s)>
- [cgal-discuss] 3D mesh of a domain with several holes, Adam Hopkins, 10/28/2011
- Re: [cgal-discuss] 3D mesh of a domain with several holes, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] 3D mesh of a domain with several holes, Adam Hopkins, 10/28/2011
- [cgal-discuss] Re: 3D mesh of a domain with several holes, adam.hopkins83, 10/31/2011
- Re: [cgal-discuss] Re: 3D mesh of a domain with several holes, Laurent Rineau (GeometryFactory), 10/31/2011
